jim dog Posted Thursday at 05:55 PM Posted Thursday at 05:55 PM The book says timing mark location Pulley or Flywheel. I'm not finding any marks on the flywheel I am on the pulley what should they look like should'nt there be a TDC stamp.There are degree marks which i had to use to set the timing. Now i'm wanting TDC to check the valve tappets. I've put about three hours of road time on a new over hall .It ran very good Starting was excelant the third time out after it warmed up I started hereing a poping noise like a exhaust leak. So now im wanting to check the tappets first. Thanks for any help. Quote
CIHTECH Posted Friday at 11:08 AM Posted Friday at 11:08 AM Adjust them by firing order, then you don't need to worry about where TDC is. Firing Order 1-5-3-6-2-4 Turn engine in direction of rotation, watch valves rock (exhaust close an intake opening) now adjust #1 Watch #2 rock, adjust 5 Watch #4 rock, adjust 3 Watch #1 rock , adjust 6 Watch #5 rock, adjust 2 Watch #3 rock, adjust 4 Roll thru it the second time to check yourself if you want. 2 Quote
jim dog Posted Friday at 06:07 PM Author Posted Friday at 06:07 PM 14 hours ago, acem said: What machine is this in? It's a 826 Farmall/ International. Quote
acem Posted Friday at 08:19 PM Posted Friday at 08:19 PM 1 hour ago, jim dog said: It's a 826 Farmall/ International. Then it should have timing marks on the flywheel. There is a pointer under the window on the housing. Marks may be covered up with dust, rust or something. Quote
snoshoe Posted Saturday at 12:44 AM Posted Saturday at 12:44 AM When the rockers are rocking on 1 or 6 those marks should be right under that window. Quote
jim dog Posted Saturday at 05:30 PM Author Posted Saturday at 05:30 PM 21 hours ago, acem said: Then it should have timing marks on the flywheel. There is a pointer under the window on the housing. Marks may be covered up with dust, rust or something. Are the marks close to the ring gear? Is there degree marks or just a stamped TDC? Quote
snoshoe Posted yesterday at 05:25 AM Posted yesterday at 05:25 AM Pretty sure it's just a T and the number every ten degrees. A mark for each degree. Aftermarket flywheel may be different. Quote
