I have a 5288 that has lost the power to the data center. I have cleaned all grounds and it has power thru the 3 amp fuse that powers the key switchThe key switch has a 5 connector plug that sends power to the data center but the plug for it shows no power but 3 of the connectors do show power.
The data center does work, i tried it in my other 5288.
Any ideas?
Tks
Check the fuse in the holder that is hanging on the wires beside of the block fuse holder
Check the 2 "hots" and the ground at the data center connector
that 3 amp fuse does not "power" the switch -- rather the switch powers the fuse
There is a data center diagram floating around this forum
I have had the pins back out on the round connector on the data center. Take a flashlight and double check to make sure they are all seated correctly
