I've always run the TSC tractor trans fluid in my machines. It's listed as "hy trans" compatible. On any of the machines I've owned, 2- td15c's, 3- 175c's, etc, no one ever replaces the suction line from the main frame to the strainer. A good set of crows feet and some Bonney wrenchs, cheap ones at harbor freight, will make the process easier. I rebuilt the torque converter and transmission on the 84 td15c I'm running now. The dash gage on it shows around 250psi when running at normal temp. I just fixed a suction issue on my td8g. The pressure came up a lot even though I have some other issues in the trans itself. It might be worth swapping out the suction lines. I'd also pull the strainer housing and check for cracks in the fitting bosses. Make sure to use a new oring when you put it back together. if memory serves, it's a -236 75a durometer o-ring. You can order a pack of them from Amazon or McMaster Carr.
