IH 560 farmer
About IH 560 farmer
  • Birthday 03/07/2000
    Connecticut
    Ih tractors
1,346 profile views
IH 560 farmer's Achievements
  1. Hi all i have a 686 and the brakes work just when you’re standing on them and closer to the floor. Was told I need to remove some shims from the brakes. Is it as simple as pulling the cover off and removing a few or is it more complicated.
  2. Could you tell me where the Inlet check valve is and how to apart
  3. Thats what i believe is the outlet of the supply pump and nothing comes out when i crank the engine.
  4. Hi all ive got another 1980 1086 im having an issue with. It will start with prefilled filters and run for probably 10 seconds then sputter out like starving for fuel. I took the feel line to the filter off and blew it out and had steady fuel and took off all the return lines and made sure they were open as well as the orfice on the back of the pump. Now I get good fuel to the first filter in the systen but nothing out of the fuel supply pump to the final filter to feed the pump do these pumps go bad? And is this something i can replace or is this best to leave to a pump shop. Thanks
  5. Anybody have a correct part number for a fan/ alternator belt for a 686 german diesel
  6. I guess we have the results it is a B model
  7. On that note can anyone recommend the best place to either rebuild or swap pumps with? Was considering area diesel since they seem popular and good
  8. I believe the tractors an 80 or an 81. So should i set timing to 15 degrees
  9. Very helpful thank you sir
  10. Injection pump needs a rebuild poor starting on tractor. Requires use of hand primer and cranking over and back and forth to get it to finally catch.
  11. Anyone have a picture of the timing marks on the pulley and where is the pointer to line them up
  12. Thanks very much danny. Do you time the 18 degree mark on the flywheel or the crank pulley
  13. Hi all ive got a 1980 1086 and i need to have the injection pump rebuilt. Can anyone guide me through a step by step process on how to correctly time the engine and remove the pump. Im mechanical inclined just have never done one on a dt414 thanks
  14. Minty ole 986 man
