les mains noires Posted 15 hours ago Posted 15 hours ago Hello everyone from France. I am reaching out to you because I feel that my country is truly a lost cause—it seems that no one here knows how to work on or repair an engine that’s having issues anymore. I’m turning to you in hopes of finding a solution for a problem I’m having with my 2006 Case IH 2388, which has 3,000 engine hours. I’ve owned this machine since 2011, and the engine "jumps" (surges or jerks) whenever the load on the rotor decreases. It happens very briefly, but the issue is getting worse over time—to the point where it’s now causing metal mounts to break. Naturally, I have already thoroughly checked and replaced everything possible on the exterior of the engine. My current suspicion is that there might be an issue with the injectors, specifically that they are allowing too much fuel to return to the tank (excessive leak-off). I’ve discussed this with every Case IH dealer in my region, but none of them have ever encountered this problem. I even had a Cummins specialist run a diagnostic scan, but nothing unusual showed up in the settings. Have any of you ever dealt with a problem like this? Could excessive fuel return (leak-off) from the injectors be the cause? Thank you very much in advance. Guillaume Quote
CIHTECH Posted 9 hours ago Posted 9 hours ago Good Day!! For us here in the US of A there are multiple serial number breaks that may not apply to your machine. It would be really helpful to know what fuel system your 2388 has. I am assuming you have a common rail system, based on your statement of a diagnostic scan. Quote
dale560 Posted 8 hours ago Posted 8 hours ago 7 hours ago, les mains noires said: Hello everyone from France. I am reaching out to you because I feel that my country is truly a lost cause—it seems that no one here knows how to work on or repair an engine that’s having issues anymore. I’m turning to you in hopes of finding a solution for a problem I’m having with my 2006 Case IH 2388, which has 3,000 engine hours. I’ve owned this machine since 2011, and the engine "jumps" (surges or jerks) whenever the load on the rotor decreases. It happens very briefly, but the issue is getting worse over time—to the point where it’s now causing metal mounts to break. Naturally, I have already thoroughly checked and replaced everything possible on the exterior of the engine. My current suspicion is that there might be an issue with the injectors, specifically that they are allowing too much fuel to return to the tank (excessive leak-off). I’ve discussed this with every Case IH dealer in my region, but none of them have ever encountered this problem. I even had a Cummins specialist run a diagnostic scan, but nothing unusual showed up in the settings. Have any of you ever dealt with a problem like this? Could excessive fuel return (leak-off) from the injectors be the cause? Thank you very much in advance. Guillaume Yes it can. I assume being it is a 2006 you will have common rail system. There is specific leak check procedure. It involves the Cummins software and plugging one injector high pressure pipe at a time . Then measuring flow from return. It is very hard to find but there is a pdf file on the fuel system trouble shooting floating around internet sites. The combine forum mostly a Canadian site has some good info. But there can be other little sensors or switches causing issues. Do an internet google search of common rail Cummins 8.3 no power after injector change. You might have a entire day of searching but on some of the sites are good pages of info. Quote
dale560 Posted 8 hours ago Posted 8 hours ago This trouble shooting manual is for a 6.7 Cummins. Although similar it is not the same. If you can find the Cummins manual for the 8.3. I have seen one labeled caps and caps11 as Cummins called later system for a bit. Look up Cummins high pressure common rail trouble shooting. You might need a Cummins service person to access their system to get you guides. I have found them online after a day or two of reading. You don’t have the caps system but sometimes the guides are combined so I posted it. Quote
HydroTek Posted 6 hours ago Posted 6 hours ago Often times a thermal scan (FLIR) will point to the leaking injector , and you won't need to do the tests described above Leaking jumper tubes will make heat that can be seen , and the injector will be cooler at the exhaust port Quote
dale560 Posted 5 hours ago Posted 5 hours ago The only way you are going to diagnose a fault on a high pressure common rail. Is the detailed flow chart and tests. With the insite tool from Cummins you can watch engine parameters . What is commanded and what is actually happening. You will need access to a Cummins service computer and time to play with it. Another thought after reading through are you sure this is an engine problem causing the vibration. The part about load decrease could be a rotor vataible drive sheave sticking also. Quote
dale560 Posted 5 hours ago Posted 5 hours ago Here are pictures of the programs you need to diagnose. If problem is engine related. The insite is the diagnostics program, quickserve is the repair manuals or procedures. As far as aftermarket heavy equipment scanners I do not know of one that will work on your machine. They have always needed the insite here to access and work on the Cummins computer. Quote
CIHTECH Posted 2 hours ago Posted 2 hours ago 2 hours ago, dale560 said: As far as aftermarket heavy equipment scanners I do not know of one that will work on your machine. I just dug around in the brains of and ECM on a CaseIH 2588 combine yesterday, using Jaltest software. I could read everything I could with Cummins Insite. Injector cut-outs, compression tests and the works. I was able to read engine history and everything. 1 Quote
dale560 Posted 1 hour ago Posted 1 hour ago 58 minutes ago, CIHTECH said: I just dug around in the brains of and ECM on a CaseIH 2588 combine yesterday, using Jaltest software. I could read everything I could with Cummins Insite. Injector cut-outs, compression tests and the works. I was able to read engine history and everything. That is good to know. I know any of the cheaper ones don’t work. You can read the basic sensors I take it also? Quote
