TriStripe1086 Posted 10 hours ago Posted 10 hours ago Was bush hogging a week ago and was attempting to back up, which I had done successfully several times just a bit earlier. Put the shifter in reverse and eased out on the clutch but noticed I didn't feel any engagement as I let the clutch partially out. I moved shift lever to park and then back to reverse and I eased the clutch completely out this time, but tractor didn't move. I shifted to park and eased the clutch out but tractor tried to move forward, and I could hear some gear grinding. Also, I can't get shifter to move left across center neutral position to go to high or low. I haven't looked under the cab floor plate yet. Is this a linkage problem or internal to the transmission? Of note, this is a factory T/A delete tractor. Thanks in advance for any responses. Quote
HydroTek Posted 10 hours ago Posted 10 hours ago Worn linkage and "speed shifting" remove the floor plate and look under at the linkages also in the console , may get a bar in there to get the linkages back in line Usually the problem in the Hi Lo linkage did not get in neutral before you went into R Quote
sandhiller Posted 9 hours ago Posted 9 hours ago 2 hours ago, HydroTek said: Worn linkage and "speed shifting" I learned the hard way on my 1486 It is a "H" pattern Not a "Z" pattern "Usually the problem in the Hi Lo linkage did not get in neutral before you went into R" @ole 815 sent me this that helped me get ungoobered, maybe it will help you Quote
