Jimbo45 Posted June 16 Posted June 16 Would anyone have a set of front International 2000 loader brackets for the Farmall 450 tractor for sale? Or the technical design drawings with the dimensions to have them made ? Thank you in advance Jim Quote
jd560 Posted June 17 Posted June 17 I can't figure out how to copy from another post or quote a link, but: Grassfarmer 75 has a post on Mar 20, 2025 (same subject as yours) with some information about the 2000 loader mounts. I have the 2 brackets shown as numbers 1 & 2 in 7and8and1456's response to his question. I took them off of a 560 and do/did not have the loader or any other brackets/parts. If they will help you, they are yours for shipping (or pickup). Quote
iowaboy1965 Posted June 17 Posted June 17 I believe these are the ones your looking for. Maybe you already knew what they looked like. 🤷♂️ Don't have any or measurements. Thought about putting one on my 400 eventually. I've got a spare parts loader but not mounts. Quote
7and8and1456 Posted June 17 Posted June 17 I have both a 2000 loader and a 2001 loader and the operator manual and parts book for both of them. The 2000 makes no mention of mounting onto M, Super M, 400 and 450 tractors. The 2001 were mountable on those tractors. However, the subframes for both loaders are interchangeable therefore a 2000 will mount on those tractors, they just need the proper mounting brackets. Here are diagrams of front bracket for those tractors . The rear attachments of the subframe to the rear axle are constructed differently dependent upon the particular tractor the loader was purchased to be mounted on, so those must be correct for the intended tractor also. 2 Quote
Matt Kirsch Posted June 18 Posted June 18 The drawings are isometric meaning you can just lay a ruler on them and get dimensions once you know one for scale. 1 Quote
