FarmallH_73A Posted November 18 Posted November 18 Hey guys I'm pulling a 1952 Farmall H and I'm running out off horsepower at about 150 feet does anyone have and tips about turning the motor up for more torque and horsepower. Thanks Quote
snoshoe Posted November 18 Posted November 18 Increase bore, stroke, compression and rpm. Guaranteed to increase both torque and horse power. 1 Quote
FarmallH_73A Posted November 19 Author Posted November 19 On 11/18/2026 at 5:33 PM, snoshoe said: Increase bore, stroke, compression and rpm. Guaranteed to increase both torque and horse power. Thank you I will try over the winter it is tempting to 350 swap it Quote
snoshoe Posted November 19 Posted November 19 10 minutes ago, FarmallH_73A said: Thank you I will try over the winter it is tempting to 350 swap it That would get you bore and some compression especially if it is fire cratered. I believe a cam and manifold upgrade as well. Not that you can't do better. There are always more ways to spend money. Quote
bwop2017 Posted Wednesday at 05:59 PM Posted Wednesday at 05:59 PM I'm not super familiar with older farmalls but would a super H cylinder head help any? Quote
rustred Posted Thursday at 03:43 PM Posted Thursday at 03:43 PM super H manifold and carb will help. and of course a good tune up , which is also checking your compression,and timing setting, little increase in rpm also. do the simple first. we have no info here as to what you have done or not done . Quote
FarmallH_73A Posted Thursday at 05:49 PM Author Posted Thursday at 05:49 PM 2 hours ago, rustred said: super H manifold and carb will help. and of course a good tune up , which is also checking your compression,and timing setting, little increase in rpm also. do the simple first. we have no info here as to what you have done or not done . The only thing done to it is a 350 carb Quote
