SMR Posted May 7 Posted May 7 Hi, doing some transmission work on a 5240 maxxum and noticed rear engine seal looks a bit ragged. Went to case dealer an they have at least 3 if not 4 options ranging from 280 to over 400 dollars! Just curios which seal others are using Thanks Quote
DirtBoyz07 Posted May 7 Posted May 7 It’s a project to replace , I’m guessing the small bolts are coming loose that holds the rear main seal cover to the block are leaking . For the seal you can get it from a Cummins dealer or your auto parts supplier too . Dodge Ram up to first half of 1998 5.9 , you might want to get the one with the wear sleeve just in case your crank has wear . You will need the gasket for the seal cover and possible the oil pan if you tear it when removing the aluminum seal cover . Red lock tight on the little bolts when you put the cover back on and sealer on the gasket on the cover . Take the bolts out that holds the front of platform or cab , the top bolts on the bell housing are 2 hours removing if you don’t lift the cab/ platform . You need to roll the entire front half of the tractor away from the transmission and the motor only is bolted to the transmission.. if your not setup to handle stuff you better take it to a shop that can , don’t want anyone getting hurt 😳 Danny 1 Quote
CIHTECH Posted May 7 Posted May 7 49 minutes ago, SMR said: Went to case dealer an they have at least 3 if not 4 options ranging from 280 to over 400 dollars! Just curios which seal others are using Current number for a "wet" housing rear main seal is 4955372 for the handsome fee of 42.75 I don't like using a wear sleeve type seal, it just creates another place for a leak and takes a special tool to install. I would suggest repositioning a std seal in the seal carrier so seal lips ride at different location on crank hub. 1 Quote
SMR Posted May 7 Author Posted May 7 7 minutes ago, CIHTECH said: Current number for a "wet" housing rear main seal is 4955372 for the handsome fee of 42.75 I don't like using a wear sleeve type seal, it just creates another place for a leak and takes a special tool to install. I would suggest repositioning a std seal in the seal carrier so seal lips ride at different location on crank hub. You get that thru case? Quote
CIHTECH Posted May 7 Posted May 7 32 minutes ago, SMR said: You get that thru case? Interstate Mcbee Quote
