I run all Milwaukee doing repair service and my biggest peeve with them is the way the battery attaches after some wear especially impacts that chatter around they tend to loose the connection and you gotta tap battery into place. Really sucks if your holding somthing in place with one hand an other running impact . Pull trigger and nothing. Almost enough to make a person switch brands on the spot
Below the hydraulic pump theres an oval shaped cover held in place with 2 bolts [suction screen inside]. Theres a wire coming to the senser in the Centre of that cover. Possibly that wire is just disconnected
Hi . Anything a person should no befour pulling fuel pump on 504 ih.
It doesn't sceem to be putting any fuel to injectors. Good flow to pump inlet . Checked inlet screen . Shutoff has full travel
Just go to a carrarro axle parts supplier with the info off the little metal plate tacked to you axle with model an serial number of axle an they should be able to get that seal kit OE at a fraction of the price
Could put a gauge in the forward clutch pressure port an make sure pressure goes to 0 with clutch in. If it does more than like a forward clutch with warped disks not releasing
Ok . Is it common that the inner teeth on friction discs goes out. Tractor quite working in med range when guy went from reverse to forward. No issue befour. Thought if pads are worn down it would mebe show signs of slippage
Is there an actual test port for the medium range clutch pack to check its pressure? Can go into the dash display an watch the pressure there but i believe that is on a shared pressure senser . Have power coming to the medium solonoid an i can make it click if I power it with tractor not running. Thinking if I could confirm it is getting pressure than somthing is wiped in the medium clutch pack
Hi, doing some transmission work on a 5240 maxxum and noticed rear engine seal looks a bit ragged. Went to case dealer an they have at least 3 if not 4 options ranging from 280 to over 400 dollars! Just curios which seal others are using
Thanks
