Idaho Waddie Posted November 17, 2025 Posted November 17, 2025 My TD7E has a few gages that need replacement. Does anybody have a source for them.? Quote
Dirt_Floor_Poor Posted November 20, 2025 Posted November 20, 2025 Do you have any part numbers? Quote
pede Posted November 21, 2025 Posted November 21, 2025 Did it have the cold/run/hot type? I'd replace those anyways, just about any auto parts store will have normal gauges that fit. Quote
Binderdan Posted November 21, 2025 Posted November 21, 2025 They are mostly a universal round gauges and can find similar ones by size and spec in a Summit Racing catalog. But for originals you will need a part number. A few are shared with tractors and still available new. For temperature gauges such as engine temp and torque converter temp I sent the originals off to be repaired. They can install a new capillary tube and bulb. 3 Quote
Idaho Waddie Posted November 25, 2025 Author Posted November 25, 2025 On 11/21/2025 at 1:03 PM, Binderdan said: They are mostly a universal round gauges and can find similar ones by size and spec in a Summit Racing catalog. But for originals you will need a part number. A few are shared with tractors and still available new. For temperature gauges such as engine temp and torque converter temp I sent the originals off to be repaired. They can install a new capillary tube and bulb. Where do you send the gauges to be repaired? Quote
Binderdan Posted November 25, 2025 Posted November 25, 2025 As I recall I sent the last one that needed a new capillary tube and bulb to Robert's Tractor. But there are others. Quote
