Idaho Waddie
Everything posted by Idaho Waddie
Has anybody added auxiliary hydraulics on a Dresser TD7E? I have a chisel plow with two actuators on it that I would like to pull with our dozer. I know I need a diverter valve and a two spool directional control valve on it. I would use the tilt cylinder hydraulics for the pressure/flow source. If anybody has done this, I'd like to hear about any challenges or difficulties you had making this modification. Jerry
International BTD20 Transmission Filter Element
Idaho Waddie replied to jeffrob's topic in IH Construction Equipment
here's what's on my late 1980's TD7E The filter assembly was a Lenz DHA1000-60R with the 5062-60 SS screen. I believe my line fittings were 1"NPT but Lenz has different fittings available. If you can't find a OEM replacement, you might be able to find a Lenz replacement. It's only a suction screen and i believe they make them with several different porosities. ttps://duckduckgo.com/?ia=web&origin=funnel_home_website&t=hundefined&q=Lenz+DHA1000-60R+with+the+5062-60+SS+screen.+ -
"...less than 50psi....." Minimum compression pressure should be > 350 psig. Did you put oil in the cylinders and re-check the compression? If the compression comes up it's most likely rings. If it doesn't, could be valve adjustment, bent push rods, burned valve, burned piston crown, etc. Do your compression checks with a clean airfilter or no air filter.
Is this the suction filter for the transmission? Did it have a screen in it? Lenz makes these types of filters and that's what I have on my TD7E. -
Dresser TD7E Fuel Shutoff Valve
Idaho Waddie replied to Idaho Waddie's topic in IH Construction Equipment
I found a ball valve on Amazon as well as a pipe thread elbow. I will remove the Vibra-log tube nut and replace it with a FNPT nut and sleeve and see how that works. I also found a used valve at Norcan in Spokane so if this doesn't work, I have a back up. Thanks for your input -
International 175 track loader
Idaho Waddie replied to Logan gent's topic in IH Construction Equipment
What kind of oil? engine or transmission? -
Thanks for the suggestion. I tried that but I have about stripped the gland nut and I can't get it to turn. -
The fuel shut off valve on our TD7E (part number 650 443 C92) is leaking from the stem. I got some packing material to re-pack the stem but i cant open the gland to replace it. I have a small ball valve and a 90 degree elbow with MNPT threads that I thought I could make work. However when I removed the valve, I found the fuel tube connection is some sort of morphodite straight thread and the tube itself has some sort of crimp on it. So I need to find a replacement fuel shutoff valve or an adapter that will go between the MNPT elbow and the existing fuel supply tube and nut Can anyone point me to where i might get a replacement fuel shut off valve or an adapter?
HAVE YOU CHECKED THE CLUTCH PRESSURES ON THE DASH? If they are low, remove the filter housing and rinse the screen in diesel and clean the trash out of the filter housing. They is a way to check the various transmission pressures in the shop manual. That would be the next step if the screen cleaning and high pressure filter change don't fix the problem.
Have you checked the suction screen on the transmission? Do you have a manual? It has the test methods to check the transmission
A compression check narrow down the problem since you have eliminated the other possibilities. Worn or stuck rings, burned or misadjusted valves, or burned piston crown are all that's left
For a non start situation you need to make sure that the injectors are getting fuel and you have good airflow into the cylinders and you have compression. Replacing parts should only occur after you have narrowed the problem to a specific cause. Pull the air filter off. Pull an injector and make sure that you getting a fine spray of fuel when you crank the engine over. Run a compression check. Low compression means either worn/stuck rings, burned piston, or leaking valves. You complicated the situation by pulling the injection pump and then questioning whether the timing is correct. Now you have to make sure you didn't change the timing.
Master Pin dimensions for Dresser/IH TD7E dozer
https://www.heavyequipmentforums.com/threads/master-track-pin-dimensions-dresser-td7e.123518/ -
Binderdan, Thanks for the drawing. They have everything dimensioned but the master pin diameter! I tried scaling it and I come up with the master pin diameter of 0.99 inches. Sounds kind of big to me. Where did you get the drawing? Thanks again for the info. Jerry -
If your transmission assy part # is 622 250 C92 then, I believe the part number 54 is a "Ring, Snap, Internal" 347 297 R1 part number
I just bought an '86 TD7E and it's serial number is XXXXXXXX104661 and supposedly at serial number XXXXXXXXX9500, the powershift transmission was changed to the small transmission. Does anybody know what the difference between the transmission was? I know that the driveshaft was changed from a relativelely short double u-joint to a 10 in shaft with u-joints on each end. What changed in the transmission itself?
Late 1986 TD7E Final Drive metal in oil.
I found rebuilt units for about $5000, I found used units for about $2500-$3000, and a repair kit (bearings and seals, etc) for around $400. My mechanic friend says about 2 day to remove and re-install. The cheapest fix is to have the owner's mechanic rebuild it with the $400 kit. I will try to convince him to do this and i will then pay full asking price for the otherwise good machine. -
I'm looking at a Dresser TD7E (Serial # 4410020U010461). It has a rebuilt engine 10 hrs ago due to a cracked oil pickup tube. I presume it has the small Powershift Tranny because of the serial number. I had my friend who is a heavy equipment mechanic check it out yesterday and the only serious thing he found was some metal in the left side final drive. The machine has about 7000 hrs on it. Is this a common problem on these dozers and how hard is it to rebuild the final drive?
IH 100C (TD-7) hydraulic / transmission trouble
Idaho Waddie replied to 2-Zons's topic in IH Construction Equipment
What does the clutch pressure gauge say? If the pressure is low, one cause is plugged filters in the supply line and/or the filter in the transmission. (I'm assuming that you have a power shift transmission.)
