boots
2,194 profile views
boots's Achievements
  1. probly mine are bent like that on the front . mine pretty wore just hopeing to get part # before taking all off.
  2. anyone happen to know wher i can locate plow poits for a 5 bottom #70 mine currently has the slightly bent down on the very front ones. would like to locate before ripping mine all off if possible. and it seems my front bolt is larger than the other 3 . i tryed looking at offical case ih parts on line i usually have good luck there for part #s but it dosnt cover or show the points or other wear items. any help appreciated boots
  3. Looked in the daylight paint popped on top of spindle where is weldedgonna need some steering parts. Suggestions appreciated
  4. Thanks I understand you now weld is still intact gonna look afterwhile
  5. Some one welded mine before i got it but will look at it
  6. Thanks
  7. How do you get to general chat always get internal error message thank you
  8. Bushogging dropped front right tire in hole .tire turned parrell with front axle. Jacks up pushed tire back correct let jack down Back to work tires don't agree with each other .you can tell not right. Checked over no signs of damage . No stressed parts no paint or grease popped off no broken parts. Only clue is between tie rod end and tire on left side about 2 in clearence right side almost rubbing tire.any help appreciated
  9. About 2 miles north of calhoun ky
  10. im in western ky wanted to plant last night deciced to wait about 2 inches at 8 am this morning made me glad i did
  11. Started beans yesterday afternoon. First few rounds always a few headaches. We're are still pretty wet here from the back water. Working on 1 of 4 hill farms. Like my homemade canopy with a 1970s fan and overhead 2 speaker radio. Man after a few hours the headphones hurt my head. Boots
  12. went down few minuites ago after night slaap to cool off return spring gone . stopping to buy lottery ticket this afternoon thanks to the forum .
  13. dad got 1466 hung up pretty bad yesterday, probly lot of brake stomping involved. well when we got it out right brake pedal stays down looked last night . all likage seems correct from outside under floor board i am afraid . but it dosnt drive like brake is appliedgoing to try to bolt or tie up pedal i need this tractor can i run it or park it and fix later ??? suggestions needed thanks boots
  14. Starting on sunshade build options on whether 2 uprights on back axlemounting brackets whether they should be 90 degrees or angled toward rear of tractor. 3pt controls are going to be in way if angled back. I feel would look better if angled back like my 1466. Using 2 in schedule 80 pipe for up rights . Just. Don't won't floppy and would rather not have a front brace thanks
  15. All it needs is front fenders!!!!
