IH1086-806-400Fan
About IH1086-806-400Fan
  • Birthday 10/26/2006
  • MSN
    nm684764@gmail.com
    Garber, Iowa (Northeast Iowa) Hill Country
    Farming, Woodworking, Metalworking, Anything IH Memorabelia, Parts, Tractors, or other cool IH Stuff.
1,390 profile views
IH1086-806-400Fan's Achievements
  1. I don’t believe the centers or rims were ever changed, but I will try to find some more pictures to get a better view of it in later years. Thanks for the help BrewCrew, and thanks for the enthusiasm everyone!
  2. Thank you very much!
  3. I am probably grasping at straws here, but I am going to try and see if I can find my grandfather’s 1466. The tractor was sold new at Rhomberg Implement in Elkader, Iowa. He bought the tractor used when it was just a few years old in the mid 70’s from Rhomberg’s and owned it until 1992 when it was traded to another local Case IH Dealer, Scherrman Implement in Dyersville, Iowa, on a 5288. We know the tractor was sold to someone near Glen Haven, Wisconsin, but have no new news of its whereabouts in the 33 years since. I do know the TA was out when the tractor was traded in. Unfortunately, I do not have the serial number, but figured this would be about the best place to ask. I do have a few pictures to help, and any help is appreciated. TIA 1975 1992
  4. Having trouble with our MX285 losing fuel prime, causing a no start. We have gone through the cycle of opening the drain on the fuel filter, tightening it back up, then cycling the key 3 times waiting until the lift pump quits. The mounting bolts for the lift pump were 1-2 turns loose, tightened them and repeated the “prime” process. Still no start. Noticing what sounds like air hissing after lift pump quits. Assuming this is not normal? All pressure lines have been checked to ensure they are tight. Side console displaying following engine codes: - 00329 - 00281 TIA
  5. Im not good with decoding serial numbers, just want to keep a registry of them, if you get someone who is good at decoding them them you should be able to find out when it was made, where it was made, and any special add-on's.
  6. Pm me information, country, state/province, city, and if you have it, history on the tractor.
  7. Is anyone keeping track of hydro 184's, or hydro 86's?
