I recently bought a case cx100 with a front end loader on it
currently it’s plumbed to work off the rear remotes
what would I need to do to put a joystick control in the cab
Thanks for any help
Does anyone know where I can find the instructions on how to remove the injection pump from a Case IH cx100
It has the 4 cyl perkins engine in it.
I have bought the dealer service manual but I’d does not have much about the engine in it
It says I need another manual but I can’t find anything with the part number listed
Thanks for any help
I am trying to replace the tachometer in my 684 IH
I have bought 2 so far from decent dealers and neither will read accurately
I know the cable and drive gear are good because I can put the spare 574 tachometer I have which is to big for the dash hole on the 684 and it reads correctly
Any ideas
Tractor was split this spring and the shuttle piston bolts were replaced
new pto drive gear installed at transmission clutch at that time
reassembled and about a week later we lost all hydraulics
tractor sit until we replaced the hydraulic pump last month
everything works fine now just the problem with the pto
What would cause pto to stop working on my case ih 485 when we press the transmission clutch
we let the clutch out and the pto starts right back up
thanks for any advice
What’s the best place to buy a replacement hydraulic pump for my 485
Is the pumps at all state ag the same as the pumps from hy-capacity etc
prices are all over the place
looked at Messick and pump they sell are made in India
just not sure of quality with any of them
Thanks for any help
So the problem we are having is sometimes the combine won’t start if you move around in the seat it will start up
I was thinking has to be a switch somewhere on the seat for that problem
Last spring my shuttle shift and pto went out in my 485. We rebuilt it this winter finding a broken bolt in the shuttle clutch pack
we put everything back together and it worked fine.
We started mowing hay with it this past week. It does great for a few hours then the pto stops
everything else works fine just the pto
you can jerk the pto handle back and forth and it will start back and then stop again sometimes
once it cools down a few hours it will work just fine again till it gets hot
Any thoughts would be appreciated
