wmoore77
Everything posted by wmoore77
We have chiggers here but most of the time in the stored hay and straw we call those hay-straw mites exact same bite thought they will itch you to death and they always seem to bite in the worst places
Sent you a pvt msg
Thanks for the information I was thinking it was 69 it’s good to confirm it
I was thinking it was a 71 thanks for confirming it Kool yours isn’t but 193 off from mine
I’m near Greensboro NC
Recently bought a 1456 IH tractor currently sits on 18.4-34’s I’d like to put 20.8-38’s on it The plan is to change the cast centers instead of using a step up rim I know the tractor has a 3.5 axles in it what centers off which tractors will fit and look right I have heard the 1456 and the 1466 both had mostly had 38’s on them and the 3.5 axles don’t want the 6 slot 86 series centers any suggestions on where to find centers and how expensive Wish I could find some close to me here in NC is there any value in the 3.5 axle centers for the 34 size rims currently on it This tractor is kind of odd it has the 34” tires and it’s a factory t/a delete 4800 ish original hours Thanks for and advice
How can I tie into the hydraulic system without plugging into the remotes
I recently bought a case cx100 with a front end loader on it currently it’s plumbed to work off the rear remotes what would I need to do to put a joystick control in the cab Thanks for any help
Thanks for that information
Does anyone know where I can find the instructions on how to remove the injection pump from a Case IH cx100 It has the 4 cyl perkins engine in it. I have bought the dealer service manual but I’d does not have much about the engine in it It says I need another manual but I can’t find anything with the part number listed Thanks for any help
I am trying to replace the tachometer in my 684 IH I have bought 2 so far from decent dealers and neither will read accurately I know the cable and drive gear are good because I can put the spare 574 tachometer I have which is to big for the dash hole on the 684 and it reads correctly Any ideas
Found them
Does anyone know where to get the seals for the steering pump on a 784 ih Thanks for any help
Does anyone have a good used plastic dash out of a 84-85 series’s case ih or ih need one for a 784 Thanks pic of what I need
Case ih 485 pto stops when transmission clutch is pushed
wmoore77 replied to wmoore77's topic in Technical IH Talk
We have only tried it with it in gear so far also it’s not all the time -
Tractor was split this spring and the shuttle piston bolts were replaced new pto drive gear installed at transmission clutch at that time reassembled and about a week later we lost all hydraulics tractor sit until we replaced the hydraulic pump last month everything works fine now just the problem with the pto -
What’s the best place to buy a replacement hydraulic pump for my 485 Is the pumps at all state ag the same as the pumps from hy-capacity etc prices are all over the place looked at Messick and pump they sell are made in India just not sure of quality with any of them Thanks for any help
So the problem we are having is sometimes the combine won’t start if you move around in the seat it will start up I was thinking has to be a switch somewhere on the seat for that problem
Does a 1640 have a seat safety switch
