attaboy Posted yesterday at 11:01 PM Posted yesterday at 11:01 PM one of the steering clutchs is siezed on my 500 crawler. so today i started working on it, Was really concerned about the thrust washer so took my time. took lots of slide hammer action but it finally came out. poked a piece of wire in there to keep the thrust washer from falling. however once it was out i seen the thrust washer looks like it is presswd part way in a bore to keep it in place, seemed quite tite so i did not try to remove it. do i need to move the other pinion to get the steering clutch out or is it easier to try pull the centre shaft rite out? Quote
Tad Wicks Posted 20 hours ago Posted 20 hours ago I don't know exactly how the 500 and the 500C & E differ, but from the books, it appears that the 500 uses 1 solid bevel gear shaft without pilots, so yes you need to move the bevel gear shaft towards the opposite side to remove the clutch. I would remove them both anyway just to check the clutches and brake lining. The pinion shaft should not only have a thrust washer but a Torrington type radial roller thrust bearing as well on the inside and outside of the bull pinion. Quote
attaboy Posted 17 hours ago Author Posted 17 hours ago yes it does almost looks like a one piece unit but i havent cleaned it up yet, but looks like i say not capable of falling out Quote
Tad Wicks Posted 1 hour ago Posted 1 hour ago These might be of some help https://www.tractorparts.com/PDFs/IH500STEERINGCLUTCH.pdf https://www.tractorparts.com/PDFs/IH500SERVICE_STRRGCLUTCH.pdf https://www.tractorparts.com/PDFs/IH500SERVICE_FINALDRIVE.pdf Quote
