fern Posted Thursday at 03:53 PM Posted Thursday at 03:53 PM i have magnum 8950 that is acting up ill fire it up in the morning and put it in gear and it moves fine. then after bout 5 min it just drops pressure and stops the tractor, from moving tractor stays on but i have no gears checked all my pressures and everything seems fine. any ideas? Quote
HydroTek Posted Thursday at 06:47 PM Posted Thursday at 06:47 PM smack your hand to the left on the shifter and hold the pressure against the handle does the tractor start moving again ? FNR cable needs all the movement that the lever can give -- especially as the linkage wears 1 Quote
fern Posted Thursday at 07:35 PM Author Posted Thursday at 07:35 PM hello HydroTek i would have to check in a bit once i get back to the farm. thank you Quote
fern Posted Thursday at 11:26 PM Author Posted Thursday at 11:26 PM ok the master clutch ended up being the problem worn clutches would have to split tractor. Quote
