WillardInc
227 profile views
WillardInc's Achievements
Newbie (1/3)
  1. Will sure check that in the morning thanks
  2. I will try swapping the solenoids. I had my son help and I watched the box, when you plug the main power to box in, the left and right lights with blink like the planter switches a time or 2 and then nothing will happen after that no matter how many times you raise and lower planter. The markers never work. If you unplug main power and plug back in, it clicks the marker solenoids a time or 2 and then nothing.
  3. This is the automatic setup
  4. I recently purchased an 800 cyclo and the markers are not working at all. I have checked all harnesses and has a good ground. When I unplug the main power to the marker control box and plug it back in, I hear the main solenoid click and one of the marker solenoids click and click again turning off. The light will come on the left marker just a split second. I wonder if the control is bad on top of the valve block. I don't know how to check. Thanks
