MagnumOwner
Everything posted by MagnumOwner
  1. I seen it, just wanted to double check as i’ve seen posts that say you need to and others that say you don’t. Doesn’t hurt to be sure haha
  2. I will check. So do i need to take that plug out of the top and refill the pump with oil or will it refill by itself
  3. I know the 466 will fly up the hill by the farm in D4 pulling the offset disc almost wide open, the 8.3 does half that with a batwing mower, It hardly smokes even under a load. It still has the under the hood muffler on it. For the most part it’s okay but you can definitely tell it has less torque/lug than the 466
  4. Hello everyone. I have a case 7120 i would like to turn up and I would like to know if this is the right plug i remove to fill the pump back up with oil after i drain it. I also would like to know how much i can turn it in before it’s too much. I have a 20ft offset disc i’d like to use it on and on the hills it struggles a little. Our JD 4440 handles it a little better but that one was turned up by JD
