International 86 series shifter
Johnathan
Posted
Hello, is there anyone that could show me pictures of the bottom side of the shifter column on a 1086 to clearly show how it is assembled for the high low reverse shifter. I pulled mine apart 6 months ago to replace the bushings in the tubes and time got away from me and can’t remember how all of the plates, spring and washers go. I tried following the diagram in the manual and the pieces do not seem to be quite right spacing wise. Any help would be appreciated. Thank you
