The pump gear I am talking about is the main hydraulic pump not the mvc pump. I lost brakes, power steering, hydraulics, and pto all at the same time and also had the warning light come on.. Does the main pump supply oil to the mvc pump? The main pump drive gear is not turning, with clutch out the counter shaft turns at inspection plate but, were the shaft come thru the housing at the main pump it is not turning. With the clutch pushed in the shaft does not turn. there is no oil coming from the test port on the main pump. The pump is less than a year old and when turned by hand it pushes oil out. Should the counter be turning with clutch in? It could be possible there is more than one problem. The next time I am at farm I will take a picture of gear at inspection plate.
