louie figone Posted January 27, 2016 Share Posted January 27, 2016 A while back someone was asking about three point hitches for TD6's. This is the one I built for my 62 series a few years back (1970) I used T340/T340A upper lift arm, upper bushings and side brace.The lower links are modified John Deere 2510. The lift cylinder is a Hy Power 3-1/2 x 8 inch with a 16 1-2 inch center to center retracted. When used the hydraulics are plugged into two of the rear outlets. The side braces were cut and brackets made to bolt to the rear of the TD6. I have the pieces to build one for my TD9B but have not gotten around to it. The hitch was made to use a Howard tiller behind the tractor as we work some steep hills, a crawler is a must. Excuse the dirt and missing paint, it's been a while since we have painted the tractor. Link to comment Share on other sites More sharing options...
Dave McCallister Posted January 27, 2016 Share Posted January 27, 2016 I'm impressed Louie. Looks nice. D Link to comment Share on other sites More sharing options...
clydethe142 Posted January 27, 2016 Share Posted January 27, 2016 I like the dirt and paint makes it look like it was born with it. If you hadn't showed your cards I would have thought it was o.e. Link to comment Share on other sites More sharing options...
