I wanted something a little more heavy duty for trail/off road use on the back of my Scout. It had to be heavy enough to hold up the whole rig and also have at least one tow point for recovery and tie down purposes. I know you all like pics so here it goes.
The first bumper I made. It was done in 15 minutes, painted, and thrown in for a next day trail ride. This one worked but wasn't as nice as I wanted it to be. (The tube is an Allis Chalmers planter frame)
EFFB6128-ABB5-4772-A75D-467DCFDDD9E6_zps
After a visit to the local welding shop for supplies.
70749DF9-3010-41E1-9DC6-05DCAA3F4FE8_zps
The goal was to sleeve heavy wall tubing into the frame and build off of that. First step was to mark and cut out the portion covering the open box end of the frame.
74C9DC74-4D00-4639-AEC4-E7320AA4D754_zps
9692E7D5-236F-4676-90B2-BE771C611007_zps
Next was to cut the sleeves
F5D3971D-CAEE-4D82-93F7-B324112252A3_zps
A5EB7709-4503-415C-A750-064211A46F99_zps
D9612A3A-AE9D-4130-AC5B-58E4328280A8_zps
And drill it out for bolts. I drilled the entire frame and made mounting bolts from 3/4 all-thread.
0C86B565-8F03-491C-82A3-53D1FE416389_zps
Holes were drilled into the bottom and side of the frame and sleeves for side to side rigidity.
0B9B31F9-140F-4D56-B106-1082CA8EAAF5_zps
Next I turned to the 2x5" box tubing for the main portion of the bumper. I wanted something other than square ends so after some sharpie work, torch, and a flapper wheel or two I ended up with a shape.
40CC0F18-73D8-465A-BFC9-75B9026F26C3_zps
403A7D0E-F49A-4CED-BA33-083297E2DBAC_zps
It also got a hole cut through the middle for the 2" receiver.
BBEBC9B6-8092-4FE2-9AAD-20961A6EB573_zps
F400385E-C67E-49EB-8C7D-90EB5E37B0F7_zps
Next up was to inlay the sleeves into the bumper and weld everything inside and out for strength finishing off with capping the holes.
04C33CAD-DEF7-453E-916D-F1145C54FAE0_zps
B909484B-9390-4D2D-A9E8-AF1FED665EC2_zps
72DCD08E-ADF2-4706-BD0A-1B25DBE2DE91_zps
Checking for level.
C17935BC-27D7-44D9-9757-7E8B4518338B_zps
Test fit and a gusset it didn't really need.
A3CDAE2D-414A-4977-8FC4-1843E8B3C8E4_zps
A289542E-646F-4B61-BE27-921B7BB07BCE_zps
Ready for primer and some IH silver paint.
1C1148FF-4E3C-491B-A1E4-F6A36AE47D72_zps
62723830-8C85-45AF-A11F-492F1BC8B632_zps
0A956C73-8C8E-458B-B724-E15BF7485AEC_zps
Final installation.
140F8A99-0D39-4568-899E-56ABA94AEF86_zps
3EBE3B81-243A-4B18-B78C-6DD17B32B4AA_zps
Looks sharp! Wondering why you didn't make it 7-8" wider to match side? Also what are the bolts for? To align? Do they go all the way though? I love the sq tube mount. Very slick looking for sure man!
1) It's hard to tell from the pictures but I spent a lot of time deciding on the final width. Right now it matches up with the body lines. I didn't want it sticking out past the body because I was afraid the ends might hook on something going down the trail.
2) The bolts go through the frame into the heavy wall tube sleeves. That makes them almost like giant set screws. With the end of the bolts going into a corresponding hole in the sleeve it gives me strength from a pulling aspect along with taking out any horizontal or vertical play and vibration.
I'm just curious; why didn't you use the holes in the frame that IH mounted the reese hitch to. NICE BUMPER!!!! I'm sure that will hold much better than the stock rear bumper mounts!! Eason
The old one was bent from dropping off a rock ledge so I wanted as much strength as I could possibly get. This one will support the weight of the entire Scout and then some.
Makes sense now. Taking orders?
No orders. I'm sure I spent way too much time building that for any profit to come from it.
Envious of talented metal work.
I learned from the school of "cut twice" and "measure once" and my work shows it. lol. lol.
Nice bumper & workmanship.
Tony
Envious of talented metal work.I learned from the school of "cut twice" and "measure once" and my work shows it. lol. lol.Nice bumper & workmanship.Tony
X2
