sugarmaker 97 Posted March 16, 2020 Author Share Posted March 16, 2020 Folks, Have been very busy with the maple syrup season. just boiled the last syrup of the season today. Our small operation keeps me busy. Had 200 folks come through the sugarhouse this past weekend! Regards, Chris Quote Link to post Share on other sites
sugarmaker 97 Posted June 16, 2020 Author Share Posted June 16, 2020 Folks, So The TD6 may come home in a week or so but the young man borrowing it says it wont pick up any thing now. I assume something is amiss in the hydraulics. A valve or seals or something. This is the ATECO loader with the hydraulic valve body in the back behind the fuel tank. Any ideas where I should start on diagnosing the non lift issue? Matt did adjust the main clutch which he said the machine now acts way better and can actually dig into a pile and spin the tracks. Glad he is youing and spry, because I would not have been able to stand on my head and get down in the cockpit. This has very high sides and no easy access to the clutch area. I want to move some dirt with it at my daughters but the lifting issue is not going to cut it. I have pictures of the tag/ name on the valve body somewhere. But I am NOT a hydraulic guy at all! Will need your help if I tear into it. Regards, Chris Quote Link to post Share on other sites
sugarmaker 97 Posted June 18, 2020 Author Share Posted June 18, 2020 Folks, Forgot to take pictures, but Matt brought the TD6 out and dropped it at my daughters. I am going to see if it will move some dirt? Not sure what the hydraulis need. But may need your help. It is a HYDRECO control valve. Where should I start to look for issues? Any suggestions would be appreciated!:) I will try and see how it does lifting dirt, and report. Regards, Chris Quote Link to post Share on other sites
sugarmaker 97 Posted June 21, 2020 Author Share Posted June 21, 2020 Folks, Some shots of the TD6. Owen was at the controls. We didnt try to move any dirt. Regards, Chris Quote Link to post Share on other sites
sugarmaker 97 Posted June 25, 2020 Author Share Posted June 25, 2020 Folks, Any guidance on the lack of good hydraulics and trouble shooting would help. Neighbor mentioned checking hydraulic filter, but I dont see any. Anyone have a clue if there might be a filter in the system somewhere? These were made before we had spin on/off filters I believe. And I dont see one of those, but maybe there is some type of screen filter in the tank or line?? Regards, Chris Quote Link to post Share on other sites
Rawleigh99 826 Posted June 25, 2020 Share Posted June 25, 2020 Can you check the pressure between the pump and the valve? Quote Link to post Share on other sites
sugarmaker 97 Posted June 27, 2020 Author Share Posted June 27, 2020 Rawleigh, There is no guage in the system. So I would need to plumb one in. Regards, Chris Quote Link to post Share on other sites
louie figone 41 Posted June 27, 2020 Share Posted June 27, 2020 Chris, if it does have a filter it would be on the suction side (to the pump). All the ones I have seen (factory IH) are located in the hydraulic tank. The relief valve in the valve body could also create the problem you are having. After all that checks out it's time to look at your pump. Quote Link to post Share on other sites
ray54 760 Posted June 27, 2020 Share Posted June 27, 2020 16 hours ago, sugarmaker said: Rawleigh, There is no guage in the system. So I would need to plumb one in. Regards, Chris Probably a good place to start looking at things. But from most other hydraulics on old crawlers 1000 to 1200 psi was tops when new. From my experience anything over 700 psi is probably OK. Quote Link to post Share on other sites
sugarmaker 97 Posted June 29, 2020 Author Share Posted June 29, 2020 Lou, Ray, Thanks for the tips on the old dozer hydraulic system. So if there is a filter in the tank how do you get to it? I am not near the machine right now and dont have the manual here. Not sure this is the std tank? I was thinking the pressure would be around the 1000 psi mark. Its on the list of things to do but down there a little ways right now. My brain is on this old shed we are going to try to throw up this year. Hope things are good in RED land! Regards, Chris Quote Link to post Share on other sites
louie figone 41 Posted June 29, 2020 Share Posted June 29, 2020 Chris, T6International has a contact for ATECO, they may be able to tell you if there is a filter in the hydraulic system. Here are pictures from the IH parts book, IH offered two different hydraulic systems for the later tractors (62 series). These pictures are just for reference to show how the strainers are mounted into the IH system. Your ATECO may or may not have a strainer. The IH system is a stainless metal mesh strainer. Quote Link to post Share on other sites
sugarmaker 97 Posted August 24, 2020 Author Share Posted August 24, 2020 Folks, I did see the TD6 a couple days ago. It was resting comfortable at my daughters house. I have been busy and have not been able to play with any tractors since mid July. The wife has been making me work on a new addition to the property. Yes a toy box for all my big toys. First this scared the heck out of me from a cost stand point. This new shed continues to keep sucking up dollars and time. I hired a father and son crew to help me build the shed. I have most of the skills but not the years of building experience. I also provided many hours of sweat equity up to this point too. I would say the percent completion would be at about 65%. Lots of details to work on and like most of my projects it may never get totally done. Here are some shots: some design work: materials: Holes and poles: electrical service redirected: some improvements in structure: me doing some triming: Jib crane base for post: jib crane install: trusses: closing it up: shingles arrive last Tuesday Ridge vent/ cap should be done today: Electric and water rough install today Regards, Chris 1 1 Quote Link to post Share on other sites
louie figone 41 Posted August 24, 2020 Share Posted August 24, 2020 Chris, that is very nice, you will enjoy it a lot. Quote Link to post Share on other sites
farmalldr 108 Posted August 24, 2020 Share Posted August 24, 2020 Good for you Chris. Your toys will like it and just in time for winter too. I like the forethought of the jib crane. Dennis Quote Link to post Share on other sites
sugarmaker 97 Posted August 25, 2020 Author Share Posted August 25, 2020 Thanks guys, Last shingle on roof! Yea! Regards, Chris 1 Quote Link to post Share on other sites
sugarmaker 97 Posted September 5, 2020 Author Share Posted September 5, 2020 Folks, Back to reality. The TD6 had a hydraulic line leak in a hose or connection. Have to look at that and get it operational again. Othert than that it seems to be starting and functioning. Hope things are good out there! Regards, Chris 1 Quote Link to post Share on other sites
sugarmaker 97 Posted October 25, 2020 Author Share Posted October 25, 2020 Folks, This building has been my 2020 project. From lots of concepts and noodling, to this Regards, Chris Quote Link to post Share on other sites
DWF 51 Posted October 25, 2020 Share Posted October 25, 2020 Very nice building! DWF Quote Link to post Share on other sites
louie figone 41 Posted October 25, 2020 Share Posted October 25, 2020 Nice Quote Link to post Share on other sites
north of 60 191 Posted October 25, 2020 Share Posted October 25, 2020 Very nice Chris... you will enjoy working in there !! Quote Link to post Share on other sites
sugarmaker 97 Posted October 25, 2020 Author Share Posted October 25, 2020 Ok, What happened while I was sleepin? Did the forum change or the imgur system? I cant seem to load a picture stored in imgur now? The format of Red Power feels different?? Is it just me? [img]https://i.imgur.com/7LIFzqM.jpg[/img] Regards, Chris Quote Link to post Share on other sites
Poorboy 31 Posted October 27, 2020 Share Posted October 27, 2020 I'm a newbie. Your shop looks really nice. I'm still trying to figure it out. 😂😂😂 Ps. I really like your td6!! Jesse Quote Link to post Share on other sites
sugarmaker 97 Posted November 2, 2020 Author Share Posted November 2, 2020 Jesse, Thanks! The TD6 may never get a lot of attention. I just own one and have had fun learning about it. OK tried a .jpeg file and it came right in, so I guess that's the key. Imgur has that option for loading pictures. Here we were doing final drainage around the shop. At least I hope its final! Also a shot of the inside today: Regards, Chris Quote Link to post Share on other sites
sugarmaker 97 Posted November 3, 2020 Author Share Posted November 3, 2020 Folks, Ok I just glanced at the views for this thread: 62.5k views ??? Really? Folks must be using it to fall asleep at night or something ?? I think I may go look at the old TD6 and try to cipher out this leaky hydraulic line issue. I dread that because I am sure it will not be a easy, or fun project! We need some picture of it anyway. And I need to bring my Allis D17 home too. Hope things are good in Red land! Regards, Chris Quote Link to post Share on other sites
Rawleigh99 826 Posted November 3, 2020 Share Posted November 3, 2020 Chris: When you pull the hose , plumb in a tee to check the pressure with. You can leave it in place and cap the gauge hole if you don't leave the gauge in it. Quote Link to post Share on other sites
