560 gas parts
1958560
My buddy has a gas 560 with a sleeve in the pan along with antifreeze. Looks like the #5 bore is cracked. I have a 301 in a 715 combine that has been setting for a while and is stuck. I am wondering if the 301 is installable and where a good place to get a rering kit for the 301 would be. how many items must be changed to make the 301 fit the 560? This tractor is not a powderpuff so getting it back together for as little as possible is the mission, I guess. Thanks, Rob
Took a closere look today, it has M&W Add Powr pistons and the crank has been ground 010, but #5 is cracked visibly in at least two places. Also when I turned it over, the #1 sleeve came up too, and can easily be pushed down by hand. Is the block fixable? If so, where can another sleeve/piston assy be found? Thanks, Rob
