axial_al Posted December 11, 2012 Share Posted December 11, 2012 Anyone have any experience converting a wide row (36-40") caseih head into a 30" head? I have a 1054 in really good shape and am thinking of buying another row unit and a set of caseih poly instead of trading it in. There is not much demand anymore for a five row wide head. The five row wide head actually has a wider toolbar than a 1063 so that is not going to be a problem; but I am wondering what else I could run into attaching the divider brackets or whatever. Thanks in advance for any advice. Link to comment Share on other sites More sharing options...
hemlockfarms5288 Posted December 11, 2012 Share Posted December 11, 2012 My uncle did a four row wide to a narrow. I know the biggest part was cutting the auger down to size. He also cut and re welded the main beam up top and lower beam underneath where the row units bolt. As far as going to poly you can save a lot of money going to GVL II series instead of case IH. Just did a total rebuild on my 963 and and I was very happy with their snouts Alex Link to comment Share on other sites More sharing options...
wally_wolff Posted December 11, 2012 Share Posted December 11, 2012 Probably won't have to cut the auger on this conversion Link to comment Share on other sites More sharing options...
MIsparky Posted December 11, 2012 Share Posted December 11, 2012 http://talk.newagtalk.com/forums/thread-view.asp?tid=212116&posts=26&highlight=20%22%20ih%20head&highlightmode=1#M1593332 This link is for converting an 800 seires to 20" rows, not quite what your looking for but very detailed information. Perhaps some of that will apply to your project. I was planing on doing an 883 to 12-20" conversion this winter, but I just found a Clarke conversion complete..... one less winter project. Link to comment Share on other sites More sharing options...
smfarms Posted December 11, 2012 Share Posted December 11, 2012 Just curious, why 5 rows? Odd number. Is your planter on odd rows? 5 or 10 ? Just never heard of odd number of rows. Around here everything is even # 4-6-8 and so on. Any advantage? Link to comment Share on other sites More sharing options...
Scott! Posted December 11, 2012 Share Posted December 11, 2012 Just curious, why 5 rows? Odd number. Is your planter on odd rows? 5 or 10 ? Just never heard of odd number of rows. Around here everything is even # 4-6-8 and so on. Any advantage? 10 wide planter A TON of innovative people on AgTalk. A lot of morons, too. Link to comment Share on other sites More sharing options...
lucky chucky Posted December 12, 2012 Share Posted December 12, 2012 there is a machine shop here in minn. that coverts 4 wide to 4 narrow I have his # someplace. i had a JD 444 wide he said it was about 2000.00 to convert . I didn't convert mine traded it for a 643 narrow. Link to comment Share on other sites More sharing options...
nate Posted December 12, 2012 Share Posted December 12, 2012 I believe lucky chucky is talking about haukos bros. In glencoe mn. They build heads and planters. Nate Link to comment Share on other sites More sharing options...
djfarms Posted February 14, 2013 Share Posted February 14, 2013 I'm looking to buy a 1054 IH corn head. How about selling me yours and save yourself the greif of converting it to a 6RN? You can call me at 605-368-6912 Link to comment Share on other sites More sharing options...
gary1466 Posted February 15, 2013 Share Posted February 15, 2013 I converted a 954 into a 6-30Added another rowunit and used poly the biggest problem was needing a longer driveshaft for one side because the coupler is in the center on a 6 row you then cut the opposite shaft shorter Holes have to be drilled for Rowunit for auger trough bolts the end Dividers are about flush with the drive chain shields. Auger and frame were not modified I did this for a customer so I would have to look at it again to see what brand the poly was it was bought from THE Company in Mount Pleasant Iowa The rear brackets had to be narrowed up and the covers over the hex shaft cut down any more questions just ask Link to comment Share on other sites More sharing options...
