cedar farm Posted July 30, 2021 Share Posted July 30, 2021 9 minutes ago, Dirt_Floor_Poor said: With an engine driving the belt pulley, how do you stop or shift gears? The belt pulley is the clutch on a two cylinder. You would just use the hand clutch as normal. BUT. The belt pulley rides on a hyatt bearing that is supposed to be greased yearly by removing the pulley. I would be concerned that the belt tension needed to not slip would be more than that bearing is made for. Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted July 30, 2021 Share Posted July 30, 2021 1 minute ago, cedar farm said: The belt pulley is the clutch on a two cylinder. You would just use the hand clutch as normal. BUT. The belt pulley rides on a hyatt bearing that is supposed to be greased yearly by removing the pulley. I would be concerned that the belt tension needed to not slip would be more than that bearing is made for. The belt pulley is essentially the same as a transmission drive pto. That is why when you pull the hand clutch it also actuates the pulley brake to stop the belt pulley. If the pulley is turning the transmission is turning. You can not shift a two cylinder tractor transmission if the belt pulley is turning. And if you pull the clutch the tractor will not stop if the pulley will not stop. It would be the same as not having an overrunning clutch on a tractor without a live pto when using a rotary mower, it would shove you right through the fence. Quote Link to comment Share on other sites More sharing options...
cedar farm Posted July 30, 2021 Share Posted July 30, 2021 35 minutes ago, Dirt_Floor_Poor said: The belt pulley is essentially the same as a transmission drive pto. That is why when you pull the hand clutch it also actuates the pulley brake to stop the belt pulley. If the pulley is turning the transmission is turning. You can not shift a two cylinder tractor transmission if the belt pulley is turning. And if you pull the clutch the tractor will not stop if the pulley will not stop. It would be the same as not having an overrunning clutch on a tractor without a live pto when using a rotary mower, it would shove you right through the fence. You are correct. I have a dozen or so 2 cylinders and should have known that. Had he been using the flywheel side it would have worked just fine. Quote Link to comment Share on other sites More sharing options...
iowaboy1965 Posted July 31, 2021 Share Posted July 31, 2021 23 hours ago, cedar farm said: We had a Wisconsin on a MM pull type combine years ago. Dad slugged it one time. That thing would not start hot. Dad slipped the flat belt of and hooked up a flat belt to the A John Deere. "It's going to start now" No it didn't. Miserable engines. If it wouldn't start hot the coil and/or condenser needed replaced. Was a whole lot of em back in the day in that condition from what I've read and stories like yours I've heard first hand. We had a c allis when I was a kid that acted the same way. Started cold but not very good hot. Quote Link to comment Share on other sites More sharing options...
U-C Posted July 31, 2021 Share Posted July 31, 2021 Quote Link to comment Share on other sites More sharing options...
U-C Posted August 3, 2021 Share Posted August 3, 2021 Promotional/ home videos filmed by Hans Huerlimann the founder of the Huerlimann Tractor and motor works in Wil Switzerland. The hay trailer in the first video was made by the Huerlimann company. And Hans Huerlimann's dad Karl Huerlimann is on the side delivery rake and the driver is Ernst Huerlimann which was for many years the factories sales person. Most of the new Huerlimann tractors bought by my grandfather where threw Ernst Huerlimann! the Swiss Army also used tractors before and after the War until sometime in the late 50s or early 60s. The Swiss General Henri Guisan can be seen in the second part, Switzerland only has a General turning war time he gets elected by Parlement.  Quote Link to comment Share on other sites More sharing options...
U-C Posted August 4, 2021 Share Posted August 4, 2021 Hans Huerlimann travelling to South America to demo his tractor D 600 with motor harrow with the goal to export them, Â Quote Link to comment Share on other sites More sharing options...
U-C Posted August 4, 2021 Share Posted August 4, 2021 Huerlimann D 600 being tested 24 hours none stop to get import licence, and 1964 plowing competition in Vienna with the D 800 Â Quote Link to comment Share on other sites More sharing options...
utility 64 Posted August 21, 2021 Share Posted August 21, 2021 2 Quote Link to comment Share on other sites More sharing options...
utility 64 Posted August 21, 2021 Share Posted August 21, 2021 Quote Link to comment Share on other sites More sharing options...
utility 64 Posted September 21, 2021 Share Posted September 21, 2021 Quote Link to comment Share on other sites More sharing options...
U-C Posted November 28, 2021 Share Posted November 28, 2021 Quote Link to comment Share on other sites More sharing options...
DT Fan Posted November 28, 2021 Share Posted November 28, 2021 Always love this thread, good to see it come back to the top! 1 Quote Link to comment Share on other sites More sharing options...
acem Posted November 28, 2021 Share Posted November 28, 2021 Quote Link to comment Share on other sites More sharing options...
Loadstar Posted November 28, 2021 Share Posted November 28, 2021 Surprised to see this thread is still going. Guess I'll post something fitting for the end of November. Massey sold a line of snowmobiles in the early seventies called "Ski-Whiz". Just one of many names that have long since disappeared from the market. 3 Quote Link to comment Share on other sites More sharing options...
U-C Posted March 5, 2022 Share Posted March 5, 2022 2 Quote Link to comment Share on other sites More sharing options...
Dirt_Floor_Poor Posted March 5, 2022 Share Posted March 5, 2022 On 11/28/2021 at 12:34 AM, Loadstar said: Surprised to see this thread is still going. Guess I'll post something fitting for the end of November. Massey sold a line of snowmobiles in the early seventies called "Ski-Whiz". Just one of many names that have long since disappeared from the market. I used to haul a lot of square bales for different people. I hauled some to an older guy once and he had one of those Massey snowmobiles in the corner of the barn we stacked the hay in. It was the only one I have ever seen. Quote Link to comment Share on other sites More sharing options...
Loadstar Posted March 5, 2022 Share Posted March 5, 2022 9 hours ago, Dirt_Floor_Poor said: I used to haul a lot of square bales for different people. I hauled some to an older guy once and he had one of those Massey snowmobiles in the corner of the barn we stacked the hay in. It was the only one I have ever seen. I don't recall seeing many of the Massey machines either but they sure did advertise. There were so many different names and brands 50 years ago that most would never recognize today. For example, this 1974 Argo. Pretty sure I posted this one way back in this thread but its so old that is is new again. 4 Quote Link to comment Share on other sites More sharing options...
U-C Posted April 24, 2022 Share Posted April 24, 2022 Quote Link to comment Share on other sites More sharing options...
U-C Posted April 24, 2022 Share Posted April 24, 2022 1 Quote Link to comment Share on other sites More sharing options...
