  • Replies 7.9k
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Here are some pics from the pioneer days in my area!
Some unique harvest equipment from the 1985 Case-IH buyers guide. I never saw any hillside machines or double swather hitches here. But the pull type axial flow combine was everywhere.
Posted Images
3 hours ago, lightninboy said:
Talk about a down-front cylinder.
Somewhere on the internet there is a picture floating around of an experimental Gleaner CII with a rotor down front just like cylinder on the regular CII.  There was two engines probably for the extra hp needs and to counter balance the rotor.  Think the picture was from the late 60s.
Sugar cane is a giant grass. The sugar is concentrated in the stems. The harvester cuts off the leaves at the top, the stalks are cut at ground level and the cut stalk cut into approx 12 inch pieces. Trash is blown out of the harvester and is left as mulch over the plants.
Cane can be harvested several times (annualy) before cultivating and replanting.
The cut pieces are transported to a mill and crushed and heated to extract the juice and sugar.
The remaining plant trash is used to fire the boilers to generate electricity to power the mill and also sold for use by locals.
Getting ready to start up the threshing machine for harvest. Might need to look for a new drive belt from Goodyear.
Pottery making in the Emmental pic was taken before 1914 by Hermann Stauder
Bild könnte enthalten: eine oder mehrere Personen, Personen, die sitzen und Innenbereich
How does one go about repairing a belt?
10 minutes ago, iowaboy1965 said:
Cut out the bad spot and splice it?
Ive never seen it done so i was curious
On 10/4/2019 at 2:37 AM, A554 said:
Chamberlain tractors were manufactured in West Australia starting after WW2.
They were part owned by John Deere when the tractor in the photo was built in the 1980s. These Chamberlains were powered by JD engines.
Here is one from 1969
french combine harvester
file.php?id=107026
file.php?id=107027
file.php?id=107028
Google traduction
Brand: BOURGOIN
Version and model: SP 235
Currently on sale: No
Advertised power (ch): 235
Date of the tariff: Mar92
Main features: 1 rotor beater-separator 4WD
Cutting width: from 4 to 5.5 m
Engine
Make of the motor: Fiat
Rated speed (rpm): 2540
Number of cylinders: 6
Cylinder capacity (cm3): 8102
Engine Power Type: Turbo-cooled
Transmission
Transmission Type for Forward: Hydrostatic
Transmission type for reverse gear: same
Cutting device
Width of the cup B (cm): 480
Number of corn beaks A: 5
Cup suspension mode: accumul.hy
Width of the cup A (cm): 420
Cutting height adjustment: hydraulic
Reel diameter (cm): 110
Reel speed: 0 to 60 rpm
Adjusting the speed of the beaters: hydraulic
Height adjustment mode of the beaters: hydraulic cylinder
Length adjustment mode of the beaters: 2 effect cylinder
Type of inversion of conveyor rotation: option
Number of feed conveyor chains: 3
Cutting height (cm): from 5 to 100
Corn equipment: included
Corn crusher: option
Drummer
Drum diameter (cm): 60
Length of the beater (cm): 200
Drummer speeds (rpm): 0 to 1150 rpm + inverter
Speed adjustment: hydraulic motor
Concealer wrapping angle (%): 126
Concave surface (m2): 75
Drum / concave distance adjustment: crank
Separation organs
Number of shakers: 0
Distinctive features of shakers: longitudinal rotor
Grids area (m2): 448
Speed Control and Fan Working Range: Hydraulic
Location of adjustment of the fan speed: the cabin
hopper
Volume of the grain bin (l): 6500
Hopper grain level indicator: warning. sound
Drain height of the hopper screw (cm): 375
Flow rate of the drain screw (l / s): 75
Cabin
Particularity of the cabin or other protection: / silent bloc
Overall design
Size of rear tires in 4 RM: 13.6 x 24
Movement width without cut (cm): 400
Wheelbase (cm): 345
file.php?id=107026
file.php?id=107027
file.php?id=107028
Google traduction
Brand: BOURGOIN
Engine
Transmission
Cutting device
Drummer
Separation organs
hopper
Cabin
Overall design
Wheelbase (cm): 345
That's really cool those that company still exist? Or was it bought up?
The brand BOURGOIN still exists.
https://www.bourgoin.fr/
This French company was bought in 2013 by the Dutch group Ploeger Oxbo Group.
This machine was produced from 1986 to 1992.
Very complex and expensive machine, difficult to position against Massey Ferguson, John Deere, Claas or CASE IH; sales did not follow.
