Loadstar Posted November 24, 2018 Share Posted November 24, 2018 9 hours ago, IHhogfarmer said: I remember seeing that video Loadstar. I like the styling of that Ford 6000. Good thing that you got both tractors running. Speaking of the Massey 444 here is an ad from 1956 showing the triple 3, triple 4, and triple 5 tractors. Would you bet that there was no 666 because Massey thought someone else could have the “devils tractor” like IH maybe haha Thats a nice Massey ad I've never seen. I was curious if they made a 222 but it looks like they went to the Model 50 instead as the next step down from a 333. Notice in this ad from 1956 they already have the name Massey Harris Ferguson at the bottom of the page. In a few more years Harris disappeared. 1 Quote Link to comment Share on other sites More sharing options...
U-C Posted November 24, 2018 Share Posted November 24, 2018 1 Quote Link to comment Share on other sites More sharing options...
IHhogfarmer Posted November 25, 2018 Share Posted November 25, 2018 Here is just a Ferguson tractor ad from 1956 about the Hi-40. This tractor has the spin out wheel rims I think the spin out rims give these older tractors more eye appealing looks. Jmo 1 Quote Link to comment Share on other sites More sharing options...
Loadstar Posted November 27, 2018 Share Posted November 27, 2018 On 11/25/2018 at 12:56 PM, IHhogfarmer said: Here is just a Ferguson tractor ad from 1956 about the Hi-40. This tractor has the spin out wheel rims I think the spin out rims give these older tractors more eye appealing looks. Jmo Looks like this Massey model 50 has the same type wheels on it. 1 Quote Link to comment Share on other sites More sharing options...
U-C Posted November 27, 2018 Share Posted November 27, 2018 Quote Link to comment Share on other sites More sharing options...
Loadstar Posted November 28, 2018 Share Posted November 28, 2018 2 hours ago, U-C said: I have that same Farmhand advertising. I think it is from 1971 or 72. Here is another page from it featuring an IH tractor running a Farmhand silage blower. Quote Link to comment Share on other sites More sharing options...
Delta Dirt Posted November 28, 2018 Share Posted November 28, 2018 On 11/23/2018 at 8:34 AM, Loadstar said: That Massey Harris ad could have been right here in Saskatchewan except for the plough. I don't think there were many, if any, still in use by 1955. More likely this one way disk tiller. This one from 1953 has the seeding attachment. Most of them did here. Ralph--- The ad talks about the "chilled washers" taking the brunt of the thrust load (with an exploded view of the set-up pictured). Question: were most of your one-way diskers set up with cast (grey iron) bearings?? Following up on some discussion we had on the diskers--------I believe they were much lighter construction than I had thought. Quote Link to comment Share on other sites More sharing options...
Loadstar Posted November 28, 2018 Share Posted November 28, 2018 19 minutes ago, Delta Dirt said: Ralph--- The ad talks about the "chilled washers" taking the brunt of the thrust load (with an exploded view of the set-up pictured). Question: were most of your one-way diskers set up with cast (grey iron) bearings?? Following up on some discussion we had on the diskers--------I believe they were much lighter construction than I had thought. Anson, in all honesty I can't remember if I have seen the inside of a disker bearing. Kind of says how good of luck I have had I guess. The one way diskers seem to fare better in rock country than the tandems. My uncle worked with one way diskers all his life and he broke his share of blades on his last Massey 360 one way. I think the John Deere blades were a little stronger. When he got a Cockshutt tandem disk he had a lot of trouble with bearings and shafts loosening up. The IH tandem disk that followed was a little better but still had bearing problems. The one way diskers have more flexibility than a tandem which probably helps blade life here in rock country. Quote Link to comment Share on other sites More sharing options...
Delta Dirt Posted November 28, 2018 Share Posted November 28, 2018 The one way might have the ability to walk around/away from a rock based on its basic design??? With a tandem disk-----or double offset; you've got blades pulling in opposite directons-------tends to make the disk want to run straight ahead. DD Quote Link to comment Share on other sites More sharing options...
Loadstar Posted November 28, 2018 Share Posted November 28, 2018 This 360 Massey ad from about 1980 is the model that I have. Just a single 15 foot but they could be hooked up in double or triple sets to cut near 50 feet at a pass. 1 Quote Link to comment Share on other sites More sharing options...
U-C Posted December 1, 2018 Share Posted December 1, 2018 Quote Link to comment Share on other sites More sharing options...
U-C Posted December 1, 2018 Share Posted December 1, 2018 A MOTRAC dealer Homevideo: Quote Link to comment Share on other sites More sharing options...
Loadstar Posted December 5, 2018 Share Posted December 5, 2018 I didn't realize Dodge pickups had the push button automatic same as the cars in 56. 1 Quote Link to comment Share on other sites More sharing options...
Loadstar Posted December 6, 2018 Share Posted December 6, 2018 From 1960, the Humble Oil Company. As far as I know we did not see this name in Canada. 1 Quote Link to comment Share on other sites More sharing options...
U-C Posted December 6, 2018 Share Posted December 6, 2018 Quote Link to comment Share on other sites More sharing options...
lightninboy Posted December 10, 2018 Share Posted December 10, 2018 I wonder how popular David Browns were in the U.S. before Case got ahold of them. Quote Link to comment Share on other sites More sharing options...
Loadstar Posted December 10, 2018 Share Posted December 10, 2018 54 minutes ago, lightninboy said: I wonder how popular David Browns were in the U.S. before Case got ahold of them. I would see the David Brown tractor ads in the Country Guide magazine in the late 1960s but never saw an actual tractor until Case started selling them as part of their line in 1974. Of course we didn't have any David Brown dealers around until that time either. This ad is from 1977. 3 Quote Link to comment Share on other sites More sharing options...
Loadstar Posted December 11, 2018 Share Posted December 11, 2018 Here is another oil company ad from 1956. I don't know if Flying A ever appeared this far North but I never saw any locally. 1 Quote Link to comment Share on other sites More sharing options...
IHhogfarmer Posted December 11, 2018 Share Posted December 11, 2018 Before we get too far off from vehicles of the mid 50’s here are two Chevy ads the first from 1955 the second from 1956. Personally I kinda like the styling of the ‘56 models 1 Quote Link to comment Share on other sites More sharing options...
U-C Posted December 11, 2018 Share Posted December 11, 2018 Quote Link to comment Share on other sites More sharing options...
Loadstar Posted December 11, 2018 Share Posted December 11, 2018 57 minutes ago, IHhogfarmer said: Before we get too far off from vehicles of the mid 50’s here are two Chevy ads the first from 1955 the second from 1956. Personally I kinda like the styling of the ‘56 models I like those "task force" vintage Chev and GMC trucks too. I have another ad from 1956 featuring GMC from pickups to tractor units. This pic from the Montgomery dam project in Colorado. Check out the chrome grille on the pickup. Quality is not great as the big two page ad was way too big for my scanner. Quote Link to comment Share on other sites More sharing options...
