axial_al Posted January 17, 2005 Share Posted January 17, 2005 Does anyone know if 358 engines from 14/1620 combines will fit in place of a 310? are block and crankshaft bolt patterns interchangeable? Thanks for the help. Link to comment Share on other sites More sharing options...
Farmall Power Posted January 18, 2005 Share Posted January 18, 2005 I thought I would bring this back up so somone with some knowledge on this might help him out. FP Link to comment Share on other sites More sharing options...
H-D Posted January 18, 2005 Share Posted January 18, 2005 Good thinking! I will help you . Link to comment Share on other sites More sharing options...
mman Posted January 18, 2005 Share Posted January 18, 2005 I not realy sure about this. I have taken out a c291 and put in a D310. I had to start at the radiator and stop at the fuel tank. I know you would have to change the oil pan and oil pump suction tube. The backing plate would need to be change. The flywheel should bolt up. I'm not sure of the timing cover being right and radiator. That all I know Link to comment Share on other sites More sharing options...
