John Deere 4430 Questions
RickR
Posted
I was wondering what are your thoughts about the John Deere 4430 and how how did it compare aginst the 1066 and 1086? What do think about the cab on the JD 4430?
Posted
Well I won't get bias on how the Deere is better than the IH. But I will give you some pointers on the 4430. On the cabs of the 4430, the early models had the yellow vinyl seat and not as much accustics. The later ones had the cloth seat used up into the new tractors. The 30 series Deere's start harder than the 40 series. We still have many customers using 4430's for their main tractors. I would personally recommend looking for a 4440, but they will bring $8000 to $10,000 more than a 4430.
William
Posted
I remember when the 30 series came out in '72. Shipped under tarps, like the 86 series did in '76.
I think most of the 4430's came out running about 130 - 140 hp (maybe depending on who was running the dyno).
Several local guys who bought 4430's found out pretty quick that they could crank out 200+ hp without too much trouble. Most of them schucked the rear ends out soon afterward. I saw quite a few split in two at the local dealership in Albany.
From what I remember, a 1066 would outdo a 4430 and stay together a little better, but the 44's could be pretty strong. I believe the 10's used less fuel, too.
The cabs were amazing to me because they were just so quiet. Deere completely isolated the cab from the rest of the tractor, so you didn't get any gear noise.
I guess I always got along with the offset muffler and door post, but I can see why some folks didn't like it. Also, the cab was pretty small, if you liked to take lunch and tools with you.
So much for ancient memories. Somebody else will have to jump in here with more info. on how they are with a lot of hours.
Posted
I had one of those 4430s for about 8 years, best thing that ever happened was the day it left......
1086 is way better tractor. JMHO
Posted
William
Agree with you on the seats. The original yellow or tan seats were crap; pretty much the same seat from the 20 series. I always felt like I was going to slide off the front of the seat.
Posted
My two main tractors right now are a 4430, and a 1086. I've had the 4430 since it was a year old and the 1086 for five years. I started out looking for a second 4430, but the price difference steered me towards the 10.
Both cabs are equally quiet, the Deere may be a little easier to enter and exit, (I have the later cloth seat) the IH is roomier. Some people say the IH's shift hard, but if kept adjusted, and you don't get in a hurry the IH is OK. Deere rides better than the 1086.
I no-till everything, so I really have no idea which tractor has the most power (both run at 15-1600 rpm most of the time in the field).
Biggest plus for the IH is fuel use..a lot less. Last year I put 108.9 hours on the Deere and used 321.8 gallons
put 164 hours on The IH and used 299.9 gallons
IH starts 100% better than the Deere (either for Johnny at 35-40 degrees...started the IH at 8 this past winter with nothing)
Biggest plus for the Deere is the Hydraulics..they are a lot faster and better than the IH (it's a 1978, old type hyd)
... Hope this Helps .........................Mark
Posted
hi we have most of the 66 series we baled with either a 1066 0r 966 for twenty years. the best thing we did is buy a 4630. alot less noise in the cab and the window on back is a lot nicer than the 66 series red cab or 86 no fuel tank in the way. I still am partial to the ihs but have lost most of my hearing in the international cabs and i am not 40 yet. The engine on a 4430 will last to 10000 to 14000 hrs with not much care. a 4630 will go to about 8000 hrs. the clutches last a long time. the transmission can give troubles but are not bad to work on once you have been around them. we bought a 77 model 4430 last year from a consingment sale it had over 14000 hrs on original bearings. just my two cents dale.
Ps if you by a pre 76 model there is a starting device cable on the pump that never works take it off and put a spring on to hold it out and the tractor starts a 100% better the later tractors have a engine oil starting reset.
Posted
Not to be one of those guys that try to talk you into something else, but you might look into the 5088-5288, they have the nice ride of the Deere tractor, the fuel usage of the '66 series, nice cab off the '86 series, really just a nice well rounded package. There seem to be a lot of them out there and priced right if you really look, just my $0.000000002
I had\have a lot of buddy's with 4430's growing up and none of them ever had any problems and were pretty happy, I was never really a fan, but my blood runs Red!
The hydroulics can be made to run fast like the Deeres, $1000 fix for both fast pumps, relief valve, and double filter kit, unless you start with the late '86 series or '88 series, then you are already good to go, you have to love the super easy steering and hydro on the Deere's.
Posted
At one time farming Sweet Corn on Sugar Cane rotation land I had 4 Rhino/Athens 167 12 foot offset disks with 26" blades to tear up the cane stubble. To pull these disks I had two 1066's and two 4430's The 1066's would walk circles around the 4430's. The good thing about the 4430's was that they didn't eat up left hand brakes like the 1066's and the clutches were better. (wet vs dry)
Posted
The 1086 uses less fuel but the shorter wheelbase makes it ride rougher. The newer the cab on either model the better, I lean toword the deere soundgaurd myself. The final drive and rear axel on the 4430 could be a problem with duals and the pump turned up. Deere took care of that on the 4440. The 4430 may start a little harder in the cold particularly if its had a valve job and the valve protrusion hight is low. They are both good tractors. How's your dealer and parts suport for either?
Posted
My Inlaws have the first 4430 that was sold at the dealer in Belleville Kansas They have done two ovehauls, first one a rod bolt broke and second one just because. it is now showing just over 15,000 hours.
Posted
I don't know if you have seen them advertised but they make this nifty invention call foam ear plugs that cost about .50 a pair. I am only 41 but I have worn them for years and even in my old ICB cab on the 1206 I can hear the radio and my phone ring but the tractor noise is drowned out. No ringing in the ears at night for me and I don't care if people think you are a sissy for wearing them but I even wear them at tractor pulls and music concerts.
Posted
My brother used to have a 1086. I thought it had a very quiet cab. The only real bad thing I remember about it was that you hardly could see the drawbar when backing up to equipment. Fuel tank in the way. The transmission shifting mechanism did need rebuilding. IH dealer did it and then it got traded off for a 4430. The John Deere was a lot smoother ride. 15 years later the 4430 is still here. Only thing it has had done was to replace the hydraulic pump.
Posted
hi again i know you should wear earplugs but you forget to put them in. I know every one has opinions but it is nice to have a cab you can listen to the radio in. My dad had a 1586 new we used it to seed and run a jd stackwagon it was more quite in the cab than the jds but you had the tank to look over all the time. I still like the internationals we use a 1256 to feed with, a 1066 to rake and grind feed, a 1566 and a 966 on the haymover . one nice thing on a ih is transport speed about 4 miles an hour faster than jd. but the cab on the jds is just a lot nicer and engine life is better. i have overhauled over a 150 jds from a and bs to 8650s and never seen a rod bolt break on a jd even though i always put new ones in whenever you change bearings. i have seen a lot of 404 466 jds with over 10000 on the original parts. the hydraulic pumps need work when they start to leak or the brakes go out and plug the system. Ihave also done over 200 ih engines from an little a to the big tractors and only seen the rod bolts break once myself on dads 915 combine hole in the block. on his 1460 a main bolt came loose with a 1000 hrs on the engine and ran that way until 2600 hrs we cold never figure out the oil pressure it would drop after running for a while. the bolt could not come out because of the shallow oil pan. both makes of tractors have there good points but just for the cab i would get a jd
just my 2 cents dale
Posted
A 4430 had a 404 motor and it was a gutless wonder and got hot if turned up. A 4440 with a 466 engine was another story great tractor.
Posted
The earlier ones the hyd dip stick was to long and the rear ends kept going out due to low fliud ,they figured this out bacause when you had implements with several cylinders full of fluid it starved the gears and bearings .
Posted
The 4430 has held up well over time. A few things to think about. The hydraulics will put out 11-13 GPM. (gallons per minute). It just depends on the shape of the pumps. They do not like to lift heavy equipment with the three point unless you get the lift assist cylinder kit put on. The standby pressure can be tweeked to 2350 psi and this helps. Most 4430's struggled to lift a 12 row cultivator. The lift capacity is not so much of an ussue now that most have stopped cultivating. The front axle pivot pins and bushings are usually shot by now. A lot of them don't take grease. Jack the tractor up and you will see. Another thing to check is jack up the rear end and see if the rear axle bearings are tight. Usually you will see or feel the axle move up or down. Also the 404 is reliable but the camshaft drives the oil pump. The two gears wear and if they wear too far the oil pump will stop turning but the engine will keep running until it seizes. The gears can be checked by removing the tach drive cover and installing a special tool. I have put on a few alarms so that if they do lose oil pressure a buzzer goes off in the cab. If the radiator top tank is still painted green it will more than likely by now have a bad core. Every once in a while they still check good but rarely. The early 4430's had a manual bypass valve that had to be manually adjusted if you were running one way cylinders on number two scv (selective control valve). Usually this is noticed when someone would run an IH planter on an older 4430. They changed the later 4430's and you didn't need to adjust the valve. They also can be prone to having air conditioning issues. Make for sure the metal lines bending on the cab left rear corner aren't rusted through. Also check the lower metal lines. Usually the return line (the bigger line) is the one to be concerned with. Just a few things to think about. There are still good 4430's out there that have been taken care of but there are some junk ones too. I just had a 4430 in the shop a customer bought cheap from an individual. After spending what he paid for it. It wasn't so cheap. Labor rates and parts can add up quickly. So look it over good.
