What model do these shutters belong too ?
fbh31118
Just wondering. I originally bought these not knowing what they went to other than they were in good shape I was thinking B or C but I'm not sure. Can anyone tell me what they go to? Thanks so much
post-6698-1218554573_thumb.jpgpost-6698-1218554587_thumb.jpgpost-6698-1218554610_thumb.jpg
Looks a lot like the shutter setup on my F-14. On the 14, it bolts just in front of the radiator and has a 3/8 adjusting rod along the right side back to a bracket on the fuel tank.
Hard to tell without measuring but look like a set for an A, B, or C.
IF you want to sell them, I'm interested.....
Al
Al
They have the same bolt pattern as the radiatior on an H but with the control on the top instead of the bottom. Its also a little shorter than the H radiator, I wouldn't mind selling them but it would be nice to know what they go to first.
Al
Can you send me a private message with the dimensions, space between the bolt holes, etc? That should narrow down what they fit.
Al
These look very like the shutters for my Super A. The H shutters have a different attachment to move the vanes. The A, B and C shutters have the control on the bottom right, looking from front, the Farmall H and W-4 have them on the bottom left. The pre-war tractors had the control on top left and it was a screw thread rod that moved the shutters from open to close. The 1939 and later tractors used a push-pull rod, directly in the A, B and C and via a screw action moving a lever attached to the oil filler neck in the Farmalls H and M and the W-4, W-6 tractors.
Exactly! I never had all of the hardware for my H to run the shutters, so there for, I never knew what end the shutter control was supposed to be on but now that I have one complete set, it makes sense.
The holes measure 16 3/4 inches across by 12 3/8 inches and 10 3/4 inches in high. For what ever reason there is two sets of holes on the bottom of the shutters.
