seabee Posted November 30, 2007 Share Posted November 30, 2007 trying to set the pressure up on a 560, pump tests good but pressure is still low (1000 psi) any tips thanks joe Link to comment Share on other sites More sharing options...
Joe460 Posted November 30, 2007 Share Posted November 30, 2007 I'd like to have more information... You tested the pump and had it isolated from the system? If you did this and got a strong reading, then based on what you've written the pump cannot develop its rated pressure while it's output is allowed to go into the hydraulic system. Is this correct? If so, then the first place to look is at the pressure relief. You could have a weakened or broken pressure relief spring. This condition will "dump" system pressure way too early not allowing the pump to develop a system pressure of 1500 PSI. Link to comment Share on other sites More sharing options...
seabee Posted December 1, 2007 Author Share Posted December 1, 2007 I'd like to have more information...You tested the pump and had it isolated from the system? If you did this and got a strong reading, then based on what you've written the pump cannot develop its rated pressure while it's output is allowed to go into the hydraulic system. Is this correct? If so, then the first place to look is at the pressure relief. You could have a weakened or broken pressure relief spring. This condition will "dump" system pressure way too early not allowing the pump to develop a system pressure of 1500 PSI. the pump was isolated, and i have had the regulator and safty block apart. i have shimed the safty with no results. looks to be impossible to adjust the regulator side. i have looked over ihc service section and there is no mention of being able to adjust the pressure. i guess i dont quite understand the system joe Link to comment Share on other sites More sharing options...
