1066 Hi-Lo shift cover
1958560
I helped a neighbor rebuild the shift on his 1066. We replaced handle parts and bushings in the vertical shaft that goes down inside the console. We also need to replace some parts in the cover. i pulled it off tonite, and I heard a clink as I pulled it up. I don't see from the top the shift fork for reverse. I am guessing that it just rotated in there and it looks like if I take the side cover off that I can get at it, but will the reverse fork or anything else fall out then?It will probably be a couple days before it goes back together so any help would be gtreat. Thanks, Rob
