acem Posted October 30 Posted October 30 My 1480 is an early model with the short dipstick that you need to crawl down into the hole to add oil. I have seen newer combines with the DT466 that had a tall dipstick/tube where you can check and add oil from up top. What parts are needed to convert to this style and which machines have the necessary parts? Thanks Ace... Quote
IHC_1470 Posted October 30 Posted October 30 https://www.messicks.com/catalogs/case/d-466-6-cylinder-diesel-engine-01-81-12-89/00-complete-machine/9e-9e-002-crankcase-and-related-parts 1 Quote
TeachersPet1066 Posted November 3 Posted November 3 On 10/29/2026 at 9:13 PM, acem said: I have seen newer combines with the DT466 that had a tall dipstick/tube where you can check and add oil from up top. My 1460 has the longer version - maybe there is a salvage 1460 with one in it. But as I type this and think about it, mine has a reman engine in it. 1 Quote
acem Posted November 3 Author Posted November 3 If anyone has one laying around I would like to buy it. Probably should be some leftover from using combine engines in tractors. Quote
IHC_1470 Posted November 4 Posted November 4 Acem I do have the parts here. Maybe you should call me. Not sure you will be able to get the lower piece out of the block without pulling the pan. Two Zero 8-924-685One. Pacific time zone before 9 am or after 6 pm. Quote
HydroTek Posted November 4 Posted November 4 Maybe don't need all that extra effort Can you not just add length to the existing tube to make it longer ? use a hose to join the two tubes together -- will also add a vibration break because of the hose section Quote
acem Posted November 5 Author Posted November 5 (edited) My dipstick tube is loose on my 1480 and comes out with the dipstick unless I hold it in place. Every time it comes out it drops dust Into the oil :( I'll give you a call tomorrow (Thursday) evening if I can remember... Edited November 5 by acem Quote
IHC_1470 Posted November 5 Posted November 5 I will try and get some pictures and send your way. I have two different tubes the correct one and one that I think could be made to work. The correct one I do not know if I can get the lower piece out of the block without dropping the pan. The other is out. Quote
IHC_1470 Posted November 6 Posted November 6 So here is what I have. Picture on the left is what most of the DT's in combines have that I have been around. The picture on the right I am sure came out of a combine motor but it is a little shorter and one piece. I can not find the dip stick that goes in the shorter one. It comes up just short of the intake manifold but certainly would be easier to check and put oil in over what you have indicated you have. The short one is out of the block so would be an easy install if yours is loose as you said. The other one would probably require me pulling the pan to get it out. Quote
acem Posted November 6 Author Posted November 6 The taller one is what I want. Is there a bracket that it bolts to??? The shorter one is the one is what I have. Quote
