AmericanClassic Posted October 14 Posted October 14 I wasn't sure where to put this, figured it was more applicable to this forum then any of the others. Ive got a 615 combine that im trying to hotrod (I know its stupid) with a d310 out of a scrapped 715 combine. The bellhousings between the two are drastically different, mostly due to the clutch driven separator in the 7 vs the belt tensioner style on the 6. In my limited visual inspection between the two setups I know the cast bellhousing on 310 won't work on the 6, so I'd like to swap the 615 housing to the d310. I know the c263 currently in the combine has a generic steel adapter plate that holds the starter and then the bell bolts to that to hold the hydrostatic pump. Is there a reason I couldn't redrill that plate to fit the d310? Can I use the 310 flywheel if I have it drilled to bolt the drive pulley to it? Ive not tore everything apart yet but figured it was worth asking before I do... that way I can just find a d282/301 for it instead haha 1 Quote
Astr Posted November 4 Posted November 4 A D310 swap could be a solid project, but I’d check the engine mounts, bellhousing pattern, clutch alignment, cooling system, governor linkage, exhaust routing, and injection setup before buying parts. The little details are what usually eat up the schedule. If the replacement is going into an older chassis, compare crank height and oil pan clearance first. It’s worth mocking everything up before final welding. Quote
acem Posted November 6 Posted November 6 Make sure your crankshaft and input shaft are in near perfect alignment when you make the adapter plate. The 310 is probably longer than the gas engine. This may cause problems. Quote
