drglinski Posted May 16 Posted May 16 Began the process of repainting the 73 today. I've gotten it mechanically where it's in good shape (rebuilt the motor in 23, steering has been rebuilt, new tires, etc). I want it to look good for red power next year. I know it's 12 months away but I dont have luxury of a heated shop here in MI so my time is somewhat limited. It's a hodgepodge of good parts but poor paint, and over spray in spots from a PO. Anywho here are some photos. 3 Quote
drglinski Posted May 17 Author Posted May 17 Here's a photo of when I brought it home in 2020. 3 Quote
drglinski Posted May 19 Author Posted May 19 Update; motor is out. Also what no one tells you about a hydraulic lift is if it leaks it'll make a huge mess of everything. A cylinder rebuild is in my future. Since oil is embedded into the wiring harness and loom, what is the easiest/best way to clean that up? (The harness is newer and doesn't need replaced). 1 Quote
Mr. Plow Posted May 19 Posted May 19 I would put some Dawn dish soap on it, work it in, then pressure wash everything. 1 Quote
drglinski Posted May 19 Author Posted May 19 1 hour ago, Mr. Plow said: I would put some Dawn dish soap on it, work it in, then pressure wash everything. Thanks Mr Plow! Quote
drglinski Posted May 21 Author Posted May 21 More stripping and bath day. The dawn worked on the wiring harness. It's easy when your Farmall M lends a hand. 3 Quote
drglinski Posted June 4 Author Posted June 4 I've done a few pieces I have a buddy with a sandblaster im going to try to see if it helps simplify the process some. 1 Quote
drglinski Posted June 29 Author Posted June 29 Hoo boy.....been a minute since I've really done any work to this. I need to get on it since I have realistically about 4 months left to paint. Since the last update I've started painting wheels, and today my friend has a sand blaster he let me work on some parts on. 1 Quote
Mr. Plow Posted June 29 Posted June 29 Eat the elephant one bite at a time!!!! Looking good! 1 1 Quote
drglinski Posted July 9 Author Posted July 9 More elephant bites. Doing what I can with a paint removal disc before I can get back to a sand blaster. Hydraulic cylinder is off for leaking seals, needs rebuilt. 2 Quote
drglinski Posted July 17 Author Posted July 17 Well, I've discovered what is the worst part about repainting a cub cadet: the stripping process. I've tried a bunch of different methods since I'm trying to do this on somewhat of a budget and they are all somewhat frustrating in their own way. Sandblasting was ok but the cabinet I was using was difficult to schedule time to use and the compressor was inadequate for the volume of sand so it plugged easy and I spent more time waiting for air than anything else. Stripping wheel on an angle grinder works well but can't get in the corners and burns through discs quickly. Wire cup on an angle grinder was good for corners but likes to blend paint instead of removing it. I picked up this sandblaster attachment for a power washer that worked well (makes a huge mess of sand everywhere and you can't recover it) but it's great for removing paint. Flash rusting isn't a huge issue if I blow the water off with compressed air quickly after I'm done. However, it has to be extremely dry beach sand or it'll plug the supply hose. I spent more time today unclogging a hose than I did any paint removal. Next time I'm paying a shop to sand blast it for me. I'm hoping once it's painted and reassembled the work will be worth it. 1 Quote
iowaboy1965 Posted July 17 Posted July 17 You will get there. I'm sure it will look great when your done. 1 1 Quote
Hudco Posted July 25 Posted July 25 wheel look nice did you do them with the tires mounted or dimounted 1 Quote
drglinski Posted July 25 Author Posted July 25 6 hours ago, Hudco said: wheel look nice did you do them with the tires mounted or dimounted Mounted. Put them in a trash bag, cut out where the wheel was, and masked off the difference with painters tape. Quote
drglinski Posted August 22 Author Posted August 22 I have more photos and progress but since the photos are down for who knows how long with no timeline to get them back you'll just have to take my word for it. 1 1 Quote
drglinski Posted September 17 Author Posted September 17 More paint added today. Frame and rear end are one. 3 Quote
drglinski Posted October 1 Author Posted October 1 Progress continues.......identifying low spots, sanding runs, touchups, repeat....in between having a life that demands most of my other time. I'm learning a lot and aren't upset with the process. Getting real close to assembly. Still in the process of painting hardware. Doing a nice job with a spray gun with minimal experience is tougher than I thought. 1 Quote
iowaboy1965 Posted October 2 Posted October 2 I dont know anything, but it looks good from here! And I'm guessing probably as good or better than it originally was. 1 Quote
