What would cause pto to stop working on my case ih 485 when we press the transmission clutch
we let the clutch out and the pto starts right back up
thanks for any advice
What happened to cause it to start operating this way ?
All of those models had independent PTO as far as I know
so , only way I can think of is the pressure plate hub is sheared , and both shafts are locked together
Tractor was split this spring and the shuttle piston bolts were replaced
new pto drive gear installed at transmission clutch at that time
reassembled and about a week later we lost all hydraulics
tractor sit until we replaced the hydraulic pump last month
everything works fine now just the problem with the pto
