856 fuel lines / and seat
hi all my fuel line joints have what i believe are thick rubber  o-rings and im after a new set
also on a side note im after a new seat but am struggling to get one here in the uk any body have a idea who will ship to the uk
regard steve
Are you on the fuel injection pump line connections? Those are not orings, they are I believe neoprene? But you can also get a metal type seal, I’ve been having better luck with the metal.
As far as a seat, search K&M manufacturing, or tractorseats.com
43 minutes ago, stevehed said:
ok thankyou do you know where i could get new ones from ?
and tanks for the info on the seat
This is what you need.  Cummins uses these on engines as well.   You just need to size them with the line you are trying to seal.   Make sure you get all the old hard one out of the nut.
I have used rubber 3/8 fuel line and cut off the amount needed.
Worked just fine.
Worked just fine.
Tef tape also works -- roll it into a string , then wrap 3 or 4 turns around the end of the old packing
Best to get new packing sleeves from the dealer -- you can also get them from McMaster Carr
