885 Brake Resovoir
The resovoir will not keep oil in it .When we pulled it off a couple of the metal tubes were sticking out of the resovoir including the drain which i understand has to be in to keep oil level to a point to feed brake cylinders .Question is what keeps them up in the plastic resovoir ?A slight shake and they come right back down ?Thank You !!
They were just a press fit -- the aluminum tube has shrank or the plastic has swelled
Use a long taper punch and enlarge the tube some will help
If the reservoir is going dry -- then the brake piston seals are leaking
Also be sure the fill tube orifice is not plugged
