1966 R190 Re-Decked
IzzieTrooper
@td9bcf180
Howdy!
Wanted to post something of substance. Pardon my lag in replying! Perhaps it's bad form/poor ownership but I've no idea what's in the truck engine or transmission wise. I'm guessing/hoping an RD406 - 450. I haven't gotten under the hood yet like I should, just replaced filters/fluids so far.
Now! What I did discover and suspicion. While I was doing this decking project I found that at some point in the past the frame was cut and welded then a sleeve bolted on. I'm suspicious that this truck used to be tandem rear axle/longer and it was cut down. Originally it was purchased/used at Kooskia Airport ID until 2004!
Regards,
Trooper.
Looks really nice!
DWF
On 2/15/2024 at 3:51 AM, jeeper61 said:
Nice job way better than the rotten deck now it’s usable
13 hours ago, DWF said:
Looks really nice!
DWF
13 hours ago, acem said:
Great Job!
Appreciate it. 😁
I'm very pleased with how it came out. It'll be even better after the wood dries out and I can seal/paint!
Regards,
Troop.
On 2/14/2024 at 11:16 PM, IzzieTrooper said:
@td9bcf180
Howdy!
Hey- no problem, Trooper. Deck looks real good. It probably was a tandem at one time. If you can find the serial number I think you can get a Line Setting Ticket with original specs. from the Wisconsin Historical Society website.
I have my serial number but I'm not having much luck with it.
My serial no. is; "FD 109807 F"
I'll go look for a VIN when I get a moment.
I'm asleep at the wheel, Trooper.  I said "serial number" when its the VIN you need, as you know.  Canucks usually say "sorry- I owe you a coffee and donut at Timmys!"
The serial number is as close to a VIN as you'll find. The BMV probably combined the model with the serial for a VIN on the title.  The WHS should be able to get your lineset with that serial.
1 hour ago, rustred said:
nice job! yes agree with the sealing of the wood. it will rot in no time.
Looking forward to putting some rust-stop on the bed, some oil based paint, and sealing that wood really good.
As before mentioned, was just a quick job to get a usable deck. Certainly better than the previous deck! 🙃
