mader656 Posted February 3, 2024 Posted February 3, 2024 Wife explorer has a parasitic drain occasionally some times its fine for a week sometimes wont last overnight any ideas where to look? Its got that sync so its A dang computer on wheels. Im lost to where to even start?
hardtail Posted February 3, 2024 Posted February 3, 2024 This doesn't help with the source but you can disconnect the negative battery cable and them meter from the post to ground for current. Does it have aftermarket command start? Also that cold snap we had pooched some batteries up here on me, those temps rip off the bandaid and any flaws become apparent.
mader656 Posted February 3, 2024 Author Posted February 3, 2024 11 minutes ago, just Dave said: Is the radio stock? Yes.
mader656 Posted February 3, 2024 Author Posted February 3, 2024 8 minutes ago, hardtail said: This doesn't help with the source but you can disconnect the negative battery cable and them meter from the post to ground for current. Does it have aftermarket command start? Also that cold snap we had pooched some batteries up here on me, those temps rip off the bandaid and any flaws become apparent. Its factory remote start.
just Dave Posted February 3, 2024 Posted February 3, 2024 How about the bezel around the ignition switch. I have a Ranger that drains like that. I have looked for a few years to no avail. My bezel is sloppy so I suspect it could be my issue? Did all the amp checking and pulling one fuse at a time at least a few times….. I put an on board trickle charger a year or so ago and quit looking .
Lars (midessa) Posted February 3, 2024 Posted February 3, 2024 Chased a drain like that on my Suburban for a couple years. Finally tracked it down, was the drivers door dome light switch. Depending on temps, that switch would sometimes work, sometimes not. Did the hillbilly repair, as the button needed to be pushed in a bit further to work proper, I glued a nickel on the door panel where the button touches.
vtfireman85 Posted February 3, 2024 Posted February 3, 2024 Do you have a DC ammeter? Hook it up at the fuse block and start pulling fuses.
Ian Beale Posted February 3, 2024 Posted February 3, 2024 1 hour ago, vtfireman85 said: Do you have a DC ammeter? Hook it up at the fuse block and start pulling fuses. The auto electrician I use suggests connecting a low wattage bulb between battery and cable and fiddling till it tells you something. In my case it was the outside mirror control switch not always returning to centre
MacAR Posted February 3, 2024 Posted February 3, 2024 This may not help at all, but do you snyc your phone to it? I had a 13 F150 that would drain the battery until I turned the Bluetooth function on my phone off. Had to jump it every morning for a week until I'd finally figured it out. Mac
1566Hog Posted February 3, 2024 Posted February 3, 2024 I recently bought a 2024 Expedition for my wife. It has the Ford Pass feature. So it has an ECM that communicates with Ford all the time. We’ve read on forums about people having trouble with their battery going dead when having the Ford Pass set up. We did a little research on the Ford Pass system before we bought the vehicle. So far so good. Now, I can say I’ve personally experienced that same issue with my Challenger MT743 tractor. It has an ECM that communicates with my dealer every day, even though I am not signed up for that service. It has a battery cutoff (automatic after 20 minutes), that ECM is not connected through the battery cutoff (I didn’t know this). Well, my batteries started going dead all of a sudden and they weren’t even that old. So I put new batteries in. It happened to be in the winter time. Well, my new batteries went dead very quickly and they also froze since it was winter and we had really cold temps. Bulged and ruined my brand new batteries. So, I took the tractor to the dealer. They confirmed that communication ECM was pulling lots of amps, when it was only supposed to pull less than 1 amp. So the ECM malfunctioned, and was killing the batteries because it was pulling too many amps. ECM was covered under warranty, but I had to eat the new batteries. Long story short… disconnect from the sync system and see if it stops the drain. Thats where I would start anyway.
nate Posted February 4, 2024 Posted February 4, 2024 Are you sure the battery is good and doesn’t have an internal problem and shorting out? We had a mercury mariner one time at work that had parasitic drain once in a while. Turned out to be rear wiper. Pulled fuse and no problems.
mader656 Posted February 4, 2024 Author Posted February 4, 2024 34 minutes ago, nate said: Are you sure the battery is good and doesn’t have an internal problem and shorting out? We had a mercury mariner one time at work that had parasitic drain once in a while. Turned out to be rear wiper. Pulled fuse and no problems. Yes i thought the cold killed the battery because it first showed when it was super cold so i swapped it for new
lotsaIHCs Posted February 4, 2024 Posted February 4, 2024 One thing we've been seeing a lot of lately is those insurance company dongles that you plug into the DLC port causing intermittent drains and dead batteries. On some cars we can pull up the battery drain over the course of the past 30 days. Normal is below 60 mA. We will see some days will have spikes of up to several amps. Usually every 7 to 10 days and it usually lasts 2 or 3 days in a row. And it isn't just the insurance company ones. We see it happen with most any aftermarket dongle.
mader656 Posted February 4, 2024 Author Posted February 4, 2024 42 minutes ago, lotsaIHCs said: One thing we've been seeing a lot of lately is those insurance company dongles that you plug into the DLC port causing intermittent drains and dead batteries. On some cars we can pull up the battery drain over the course of the past 30 days. Normal is below 60 mA. We will see some days will have spikes of up to several amps. Usually every 7 to 10 days and it usually lasts 2 or 3 days in a row. And it isn't just the insurance company ones. We see it happen with most any aftermarket dongle. No dongles. But interesting
