886 TA
Vanstractors
Have an 886 we put new TA,Clutch ,Mcv Pump in (left actual MCV alone )Hitch pump fine steering brakes clutch fine .Ta seems to be in low will not shift .Have gauges showing zero lube pressure as well as zero from the bottom relief plug .When i pull relief and install gauge i lose steering ?Put relief back in all fine again but still no lube pressure .Am i running on pressure from supercharge line only ?Top relief stuck ,we did fool with this for a year or so ?So been down a while .Thank You !!
