TD8E
DSartin
Have a early 70’s model TD8E. Motor is currently out and at the machine shop. Everything is standard has new cam bushings but will need a crank. Head was rebuilt at time of previous in frame. Approximately 10hrs on parts. Head gasket didn’t hold so pulled motor sent block to be decked. New water pump and transmission was rebuilt just prior to when I bought it. Oil cooler does have leak but radiator is good. Has limb risers and all side shields. Tractor operated as should before tearing down. Asking $4500.00
