They must of got some air
jeeper61
Hard to believe that it is a real picture of road that buckled up like that
I saw one like that on the Schuylkill Expressway just outside of Philadelphia many years ago. It didn't buckle from heat rather the slab sunk on one end achieving the same kind of launch ramp. Lots of damage.
Normally concrete roads heave around here.  I have seen one like that.  Normally it's hotter then blazes and everyone has gone home for the day.  It takes a couple hours to remidy this type of problem, usually both lanes of traffic.
We called that a Blow Up....usually not as severe.
Hammer out a foot & half across, patch with cold mix, good until Pavement Repair crew can get to it.
On 11/5/2023 at 5:21 PM, nomorejohndeere said:
If holes in the road are called pot holes
what do you call that?
A crack joint.
