C engine
jjs48
1 hour ago, jjs48 said:
I have a 1948 Farmall C engine block number is 251069r1  where the serial number is supposed to be is  4269 . No FC just that 4 digit number. What have I got?
I don't believe it ever had the letters on the engine block serial numbers. On some models the block and tractor share the same serial number others because of power units and other things sharing the same engine they weren't all the same
There was a redpower article recently on C c113 and c123 engines used on C last few months of 1952 ,
Should see a cast C123 over the magneto, distribution lighting wheeler.
good, to long ago to give anymore info
Keep digging for more info
I was told once that a few of the Super C’s got the 113 from the factory instead of the 123. The Super C that’s been in my family since the 50’s (not purchased new) has the 113 in it.
1 hour ago, axial_al said:
Couldn’t you put the super c sleeves in a 113 block to make it 123?
I thought so.
I had a c with a super C block in it iirc.
That one I don’t think some sleeves are the same revision s took place be good with the parts book and serials numbers
