Farmall H Project
I recently picked up this tractor at an estate sale. It has been outside for many years, and they guy who owned it passed away. I bought because the motor is free, and the fuel tank was clean, and I need a mower for a farm I cut. I bought a new 12volt battery to replace the old one that was on it. I think they had a trickle charger on it, and I think they just ran the tractor off the battery as there is no generator, or alternator. I wanna go over the wiring configuration on this tractor, and any help would be appreciated. So we got a new battery, we have a starter switch, a run switch, starter solenoid, starter, distributor, coil. I wanna make sure everything is connected properly. Thanks in advance
Do you wish to put a generator or alternator on it?? First thing is make it negative ground. Looks like you have battery, positive ground. Simplest wiring would be a one wire alternator. No regulator required as with a generator.
