F-20 engine lifting
660 driver
So we are in process of swapping engines in one of our f-20's. My question would be,where is a good spot to lift a complete engine? I thought if we ran chains to all 4 motor mounts that would work but might take some finegelling.
X2.   A F-20 engine isn't a Cummins 855!   A couple 2" straps is plenty!
If you don't want to do that find any 2 bolts (>3/8" preferred) at opposite corners on/near the head and make a couple short bars with 2 holes - one for the bolt, one to bolt/hook a chain too.
