Turbo and manifold for a d310.
mike656
Makes them NOW? No. 40 years ago, sure.
You'll probably need to find an old setup, or roll your own. I can't remember if it's the 310/358 or the 312/360 that the Cummins 12 valve turbo exhaust manifold fits... Know anybody with a CNC waterjet or plasma table? They could cut you up a set of flanges and all you'd need to do is some tubing work.
That's the 312/360 that you can modify a Cummins manifold to fit.
12 minutes ago, mike656 said:
Do you guys know if a 310 is a cross flow head?
  If so what side is the exhaust on?
  Thank you guys.
The exhaust is on the right side of the engine. It's a cross flow head.  Check with some of the construction equipment salvage yards. Some of the construction equipment used turboed 310s or 358s.
4 hours ago, mike656 said:
Is there anyone who makes these?
Would i need to find an m and w set up?
Found a nice 686 I'd like to pull.
 Thanks guys!
You probably need to "girdle" the rear end as the housing is near the end of it's limit with 70-80 horsepower.
